HS 250h Model (2010-2012)
LED Fog Lights
Old 03-22-13, 03:19 PM
TonyHS
TonyHS's Avatar
Default LED Fog Lights
Has anyone tried these?
http://mtqinc.com/nokyausa/led_access/fog/fog.php
They should fit according to this chart
http://www.ebay.com/itm/HID-White-6W-High-Power-LED-Fog-Lights-Foglights-Assembly-For-Lexus-Toyota-Scion-/130781237292?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e732b502c
Not surprisingly a lot of the Toyota and Lexus use the same fog light. I was wondering about that one day seeing some of the fog lights on the current gen Prius and some Corollas.
Old 03-22-13, 08:06 PM
Ro_Ja Boy
Ro_Ja Boy's Avatar
LED *****s
Old 03-23-13, 05:32 AM
Stoodo
Stoodo's Avatar
900 lumens is very weak but they might look good.
Old 03-23-13, 08:09 AM
TonyHS
TonyHS's Avatar
Color might be a good match, depending on the LED in them. What is considered a good fog light output? I have a Philips LED bulb in use in the house. It's 18W and puts out 900 lumens. So this does it in half the wattage. I have a set of old PIAA pro fogs that I remember putting out a pretty good amount of light, maybe I'll dig them up and see how they compare to my 18W flood light bulb.
Here's an interesting ad.
http://www.adventuremotorcycleparts....TT-D1-KIT.html
Maybe I'll see if I can find a HID fog light set instead. Looks like HID has a little bit of efficiency according to the chart on the site.
Old 03-23-13, 02:46 PM
TheAirman
TheAirman's Avatar
Like he said, 900 lumens might be a little weak. I think your standard 55 watt 9005 fog light bulb is about 1800 lumens. About twice as bright. And then you could upgradde to a 100 watt bulb and throw out tons of light.
And at 5300 K, that's pretty blue. It'll have that "cool" modern look, but I doubt it'll do much for being an efficient fog light. You might want to look at something in the 2300 K to 2800 K range. Something a little more yellow.
Here is a good article on just that color for fogs that explains it way better than I could.
http://www.danielsternlighting.com/t...ght_color.html
Old 03-25-13, 10:49 AM
TonyHS
TonyHS's Avatar
Now Airman, I don't disagree with you or Stoodo that 900 lumens is not that great of output for $300+ However I believe the standard h11 bulb in our cars are somewhere under 1000 lumens. Even in the artical you llinked a standard 55w 9006 bulb has 1000 lumens. Yes I do agree with you a yellow bulb would be much better for fog, I've had pretty nice yellow PIAA fog lights in the past.
Now for some really nice lights, maybe for the same price I can retrofit some HID bulbs, at 35w I can have about 3500 lumens, so even with a yellow filter I could afford to loose lots of light and still have a very good fog light system!
Old 03-25-13, 12:56 PM
Stoodo
Stoodo's Avatar
I stand corrected on 900 lumens sucking... The regular H11's are ~1200-1300 lumens. I say close enough.
I wouldn't put HIDs in due to the lack of a projector.
Old 03-25-13, 09:09 PM
TonyHS
TonyHS's Avatar
But you can add a projector.
http://store.ijdmtoy.com/ProductDeta...71&click=13811
Old 03-26-13, 05:44 AM
Stoodo
Stoodo's Avatar
I'm tempted to do the ones you linked to in the first post. I hate (and am very poor at) removing the wheel well liners to get to the fogs though, so I'll probably wait for one of you guys to do a write up.
Old 03-26-13, 07:36 AM
TonyHS
TonyHS's Avatar
Actually it looks like you dont need to remove the wheel liners at all.
You have to remove the WHOLE FRONT BUMMPER!!!!!
Yes I was using all caps because I was YELLING!!! lol
I'm still trying to find a more cost effective option before I tackle this one... Maybe I'll just end up putting the yellow film over the lens, so the light color looks different enough from the head lights.
Old 03-26-13, 07:43 AM
Stoodo
Stoodo's Avatar
Whole front bumper?!?!?!
I'm out!
Old 03-26-13, 08:59 AM
Ro_Ja Boy
Ro_Ja Boy's Avatar
Why so hesitant to remove the bumper?
Old 03-26-13, 09:42 AM
TonyHS
TonyHS's Avatar
A major PIA. Risk damamging a major part.
Old 03-26-13, 10:07 AM
Stoodo
Stoodo's Avatar
I'd likely scratch the crap out of it and never get it back on properly. I am betting that you can still get to the fogs through the wheel well linings...
Old 03-26-13, 02:40 PM
TheAirman
TheAirman's Avatar
Maybe not the whole front bumper, and you're handy, and you don't mind scratched up arms. But that's why I did this:
https://www.clublexus.com/forums/hs-...hts-on-hs.html
Quick Reply: LED Fog Lights
