HS 250h Model (2010-2012)
Old 12-16-14, 11:41 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
How to Change of Dome's Lights
Old 03-18-12, 11:41 PM
homoonar
homoonar's Avatar
Question How to Change of Dome's Lights
Hi
I've been wanting to change the two map lights from OEM to led.
but couldn't in my life figure out how to open that light cover.
anyone experenced with changing the interior lights can tell me how to take it out?
Old 03-19-12, 06:05 PM
TheAirman
TheAirman's Avatar
I did that. And let me tell you, it's not easy. Use caution because it would be easy to bust that assembly. You would think that the light covers would just pop off, but they don't. You basically have to pull that whole assembly apart.
You will most definitely need a plastic interior molding removal tool. Try Harbor Freight. Maybe $10 for a complete set.
Real fast "how to":
Open the sunglass holder door if it's not a Premium. If it is, pry open the panel there. In there is 2 screws that have to come out. Then pry with the molding tool the 2 plastic rivets at he sides near the front. The whole assembly will hang there on the electric wire.
Here is the .pdf on how to do it.
File Type: pdf
Old 03-21-12, 06:55 PM
homoonar
homoonar's Avatar
Thank you very much man
Old 03-27-13, 10:40 PM
bimmer16
bimmer16's Avatar
Real fast "how to":
Hi TheAirman, I'm new to the forum and was wondering where you got your .pdf manual? love to get a copy if you have it available.
Old 09-09-13, 06:55 AM
mohammadgt
mohammadgt's Avatar
Real fast "how to":
Since it sounds a little complex, can you verify that it is a 175 bulb as mentioned online?
scottone92
LX - 3rd Gen (2008-2021)
09-25-16 04:51 PM
misterk
03-24-14 10:28 AM
stw2046
RX - 3rd Gen (2010-2015)
35
05-19-11 02:14 PM
BRIANxJDM
GX - 1st Gen (2004-2009)
13
04-15-10 09:07 AM
czerkawski
07-05-09 01:28 PM
Quick Reply: How to Change of Dome's Lights
