HS 250h Model (2010-2012)
My Goodness, it's driving me Crazy!
Old 08-29-13, 11:59 AM
babbles
babbles's Avatar
Default My Goodness, it's driving me Crazy!
My 2010 HS has been dropping gas mileage steadily. Went from about 37 to now about 30 in a week. Is gas mileage lower in the morning when your car hasn't been driven? Should I inflate my tires above the recommended 32psi? Thanks.
Old 08-29-13, 04:40 PM
Magellan55
Magellan55's Avatar
Did you have a significant change in the weather? Fill up at a different gas station? Change your driving pattern? If all of the above are "no", then that's quite a change. I assume you did check your tire pressures to ensure you don't have one going flat. Also check your wheels after you've driven - if any are really hot, then you have a sticking brake caliper. Could also be a clogged air filter, or water in the gas tank.
If you go another tank and it's still 30, and feel you haven't significantly changed anything about how you drive from when you were getting 37, then I'd take it in and have it checked.
gs350lex
07-29-19 09:09 PM
Brabusx2
05-02-12 11:43 AM
ntwrkguy1
Performance
22
02-03-12 10:54 AM
LEXXXIS
IS - 1st Gen (2001-2005)
11-15-10 08:10 PM
CyBorG
02-09-07 07:22 PM
Quick Reply: My Goodness, it's driving me Crazy!
