Last edit by: IB Advertising
Browse all: Steering and Suspension
- IS GS: How to Install Lowering Springs
Step by step instructions for do-it-yourself repairs
RSR Lowering Springs Installed
Thanks to everybody that helped get this ball rolling (RSR USA, VIP Auto Salon, TheAirMan & BluePrint).
My friend and I installed the springs last night without knowing too much about what specifically was involved on the HS. I would say that accessing the front upper strut mounts were possibly the most time consuming part of the whole ordeal as you have to remove the wipers, plastics and are supposed to remove a lot more. We opted to loosen a few bolts on the metal tray that sits above the strut mounts as it would have been a lot more steps to get that entirely removed. We then got a ratcheting wrench on the nuts and were able to remove them/re-install them.
Front springs were then pretty straight forward. The rears were pretty straight forward as well other than figuring out what some of the owner's manual meant by part names. Originally figured we'd have to access the upper shock mount in the rear, but you don't, so you don't need to even go into the trunk. Got it sorted and finished installation within a few hours.
Here are a few pictures:
Front spring comparison:
Rear spring comparison:
Some shots still on OEM wheels which will be replaced within the next couple weeks:
The springs seem to ride slightly stiffer than stock, but not overly noticable. The girlfriend test will be the real indicator. I expect it will settle a bit more and am happy with the drop.
I will get many more pictures once the wheels are here to show height better. Can post some before photos of the car if anyone wants to compare.
I like it!
Looks good!! I would love to know your thoughts after riding it for at least a good month or two.
Also, are you planning to get rid of your wheels?
Here's a picture I took near sundown last night after seeing your post which hopefully helps a bit more:
For comparison, here was the car before:
I will likely keep my OEM wheels as I tend to not keep cars for long periods of time and don't want to have to find a set or only be able to sell to one looking for aftermarket wheels.
Guest
Posts: n/a
I am stunned I have gotten this wrong for 3 years. Looks like someone is getting springs and wheels
I CANNOT believe I got that wrong. Wow. Seems 19x8.5 +45 works with no issues, 225/40/19.
Looks really good sitting lower! Glad to see someone modifying one of these, they seem rare enough on the road, let alone modified ones! Looking forward to seeing the drop paired with 19's!
Sounds like Mama Blueprint will be rolling in style soon!
You had me worried last night when you posted the 5x100 comment.
I think I may be the first USDM HS250h lowered without cutting springs. Not sure what VIP did on their past cars, but know at least some of them were cut springs.
Anyone that knows me will tell you I can't keep anything stock.
Kendhal
Suspension and Brakes
03-09-04 06:16 AM
persian451
10-01-03 07:59 PM
