Premium or Regular Gas ? - Page 4 - Club Lexus Forums
View Poll Results: What gas do you use ?
Premium 434 82.35%
Midrange 36 6.83%
Regular 57 10.82%
Voters: 527. You may not vote on this poll
Thread Tools Search this Thread
Old 03-15-06, 08:12 PM   #46
fastball
Gas station down the street from me sells 104 octane
It's $2.89/gal.... you think I could run the IS250 on it?
fastball is offline   Reply With Quote
Old 03-15-06, 08:22 PM   #47
rominl
exclusive matchup
rominl's Avatar
sure, good way to waste some money seriously, getting 91 and 93 i can understand, but getting race fuel is't going to help...... you are not driving a FI cars or so
rominl is offline   Reply With Quote
Old 03-15-06, 08:54 PM   #48
CodyLexus
CodyLexus's Avatar
High compression engines require premium fuel to resist detonation. Also forced induction and advanced timing.
CodyLexus is offline   Reply With Quote
Old 03-16-06, 01:17 AM   #49
Kamikaze2b
Kamikaze2b's Avatar
I only use premium. I can't understand why somebody buys a $45k car and wants to save a few bucks a month. If you're that cheap by a friggin Kia!
Kamikaze2b is offline   Reply With Quote
Old 03-16-06, 02:09 AM   #50
Big Andy
Big Andy's Avatar
I was running my IS250 on regular in the UK (which is 94 octane but I think the octane ratings are calculated slightly differently between the US and Europe) then I switched to premium which is 97 octane. The difference is definitely noticable with better pick up. Since we are currently paying over $6 per gallon over here, reading a debate between paying $2.60 or $2.80 a gallon in the US somewhat passes me by!
Big Andy is online now   Reply With Quote
Old 03-16-06, 03:36 AM   #51
mcfly
Quote:
The petrol used in the US vs that used in Europe is EXACTLY the same. The only difference, as you mentioned, is the rating system.
The US uses the (RON + MON)/2 method, where Europe only reports RON.
mcfly is offline   Reply With Quote
Old 03-18-06, 06:53 AM   #52
fastball
Quote:
We have some local race tracks around my side of town, and alot of people here have dedicated race cars (like a gutted 78 Camaro with nothing but a seat, roll cage, and a 780 hp nitro burner), so there's enough demand around here for the good stuff for one gas station to cary it.
Old 03-18-06, 01:37 PM   #53
Aterrex
Aterrex's Avatar
I just bought premium fuel. *cries* and i got a mountain dew. But its honestly not that bad. I spend more money it turns out on regular gas just fot the Land Cruiser than i do on the Is. Is has mad good gas milage for someone used to the 15 mpg highway on the Land Cruiser. So Im happy. I beat out my first 325 today on the way back form an errand. Pure Bliss.
Aterrex is offline   Reply With Quote
Old 03-18-06, 03:28 PM   #54
Rockville
Default The IS250/350 engines are designed to use...
91 octane or higher. If you put a load on the engine like going up a steep grade with extra folks in the car with you and you have 87 Octane the gas will preignite due to the lower burn temp. of the regular with great torque demand on the engine.. This is not good. The 12 to 1 air/fuel ratio is very lean and gives you the excellent gas mileage. I would let anyone run the older LX470 (Land Cruiser) engine on regular but never would I let an owner put it in the IS250/350. The price spread is not that significant anyway compared to the consumption of a heavy truck. Why would someone buy a performance sedan and then feed it the wrong diet? If anyone answered the poll with under 91 Octane then they should protect their investment and go to high test immediately. Put the regular in the Land Cruiser. BTW if an engine is designed for regular then it won't run well on Premium either. Some lawn mowers are designed for regular. If the mower is filled with Premium by mistake it will be very hard to start due to the higher burn temp of the Premium. DO NOT USE Regular in your IS.
Rock
Rockville is offline   Reply With Quote
Old 03-19-06, 09:20 AM   #55
casey225
casey225's Avatar
I know some have calculated the improved gas mileage and efficiency of premium gas offsets the price difference. Also, for the same incremental price difference between grades ($.08 - .10) you only go up 2 in the octane rating from reg --> mid, but go up 4 from mid-->prem. So I would consider that more BANG for your buck - literally and figuratively
casey225 is offline   Reply With Quote
Old 03-19-06, 06:35 PM   #56
JamRWS6
Quote:
With the 250 running a 12.0 compression ratio and the 350 only slightly less it is just ignorant to put regular fuel in these cars. Honestly, if you can't afford the few extra dollars each time at the pump why would you buy this car?
Knock/Pre-ignition is a FAST way to kill a motor.
JamRWS6 is offline   Reply With Quote
Old 03-19-06, 10:33 PM   #57
LSUFanMan
Premium ONLY! Read manual and fuel door.
LSUFanMan is offline   Reply With Quote
Old 03-19-06, 10:39 PM   #58
Jhoo
Default for those penny pinchers
So heres my solution to those who are having a hard time biting the bullet on premium. Sign up for the citibank dividends credit card and you get 5% back on purchases made at gas stations, grocery stores and drug stores, 1% on all others.
That makes that $2.60/gallon only $2.47.
Jhoo is offline   Reply With Quote
Old 03-20-06, 06:41 AM   #59
Aclarke
In NJ, we can't fill up our own tanks so somehow the dude put a full tank of REGULAR in my car 2 weeks ago... WHAT A PERFORMANCE DOWNGRADE... My car lacked all zip that it once had. Once I refilled with Premium... everything was gravy again
Aclarke is offline   Reply With Quote
Old 03-20-06, 08:19 AM   #60
Ramon
I only use Premium gas in my 350. My previous vehicle (which I still own) is a Pontiac Grand Prix GTP (supercharged 3.8) which also required premium and thats what it got every time I filled her up. Even now that its pretty much a beater car I still put premium gas in there. Any car that requires premium fuel tends to also get better fuel economy with it so the money you save on gas is not as much as you would think. The added inconvienience of having to stop and fill up more often as well as the risk of damage to the vehicle should be incentive enough to use premium fuel without question IMO. You might be ok on regular on a cold winter day, but you'd be asking for trouble if you had it in your tank on a hot day with your AC blasting. Especially if you start going up an incline or decide to open up the throttle. You're almost garuanteed to have pinging and/or a lot of knock retard.
Ramon is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Regular or Premium Gasoline Required? sderman RX - 4th Gen (2016-present) 68 03-08-17 05:15 AM
Shell vs. Chevron gasoline conboi GS - 4th Gen (2013-present) 47 11-10-15 04:37 AM
Increase gas mileage Toyboy300 GS - 2nd Gen (1998-2005) 15 08-28-09 10:37 PM
2008 rx350 gasoline CRHOPE RX - 2nd Gen (2004-2009) 4 12-04-08 01:07 AM
Gas Octane 2spark RX - 2nd Gen (2004-2009) 54 08-18-07 12:02 PM
Tags
2002, 430, 87, cruiser, es350, fuel, gas, georgia, is250, land, lexus, maxima, mileage, pennsylvania, premium, regular, worse
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
  • Ask a Question
    Get answers from community experts
What's your question?
Send
