Premium or Regular Gas ? - Page 3 - Club Lexus Forums
View Poll Results: What gas do you use ?
Premium 433 82.32%
Midrange 36 6.84%
Regular 57 10.84%
Voters: 526. You may not vote on this poll
Thread Tools Search this Thread
Old 03-15-06, 10:18 AM   #31
Lets Drive
Lets Drive's Avatar
Quote:
Originally Posted by GreyHound
Exactly. With the higher compression you need to have a more accurate explosion. 87 octane is more unstable as compared to 93 octane.
Lol, I think the words "controlled burn" would be more accurate than "explosion" when describing the igniting of the A/F mixture, lol
Lets Drive is offline   Reply With Quote
Old 03-15-06, 10:23 AM   #32
Aterrex
Aterrex's Avatar
Quote:
Aterrex, when you say you used Costco gas in your Land Cruiser, did you still use the high octane? That's what the IS owner's manual means when it says "premium" is required. Name brand gas is probably better in the long run than discount gas (which is basically a mix of leftovers, with no guarantee that the additives will be consistent). But the octane level is the more important thing. Also, if premium for the Land Cruiser is just what the dealer told you--rather than what the owner's manual actually called for--that makes a difference.
I actually know a Toyota mechanic personally and he said the Land Cruisers or LX engines can use 87 octane and get away with it fine. Well, I talked to the dealer today. Nally lexus if you guys live in the Atlanta area. He said Mid range is fine. But hearing your arguments for 93 octane rating and weighing the facts that my daily driving is about 70 miles a day. I will most likely go to a 93 octane rating. Now Another question i have. Do certain gas stations make a better mixture of gas and synthetic chemicals ? I just go to the Bp on the corner. But does anyone have any preferances ?
Aterrex is offline   Reply With Quote
Old 03-15-06, 10:25 AM   #33
yellowssm
yellowssm's Avatar
I wish we had 93 in las vegas
yellowssm is offline   Reply With Quote
Old 03-15-06, 10:31 AM   #34
Lets Drive
Lets Drive's Avatar
Quote:
I use any top tier detergent gasoline, most preferably Shell V-power 93octane (do to my cars unique engine and boost). However, I think most any brand that offers fuel additives above that which the EPA specified is good for any engine.
A few years ago, BMW, GM, Honda and Toyota ran their own test and arrived at the conclusion that these types of additives are beneficial.
Check it out here for more detail:
http://www.sfrcorp.com/notice.asp?NoticeID=4
Old 03-15-06, 11:01 AM   #35
thph27
I switched from Shell V-Power to BP 93 octane. My car seems to run much better on the BP gas.
thph27 is offline   Reply With Quote
Old 03-15-06, 12:22 PM   #36
kensteele
kensteele's Avatar
If you were going to buy, at a great price, a used IS350 with 50,000 miles on it and the one owner original owner told you he used regular gasoline everyday since day 1. He had read in the manual where it said premium, but it's all the same. Will that be cash or cashier's check?
I'm pretty cheap myself but I'm not stupid. The risk is too high for me with the risk being measured strictly in dollars. Premium...every drop.
kensteele is offline   Reply With Quote
Old 03-15-06, 12:35 PM   #37
Jimmer350
I agree - Lexus wouldn't say to use XX octane if they didn't think that's what you should use. It's not like they are getting kick-back from the gas companies.
Jimmer350 is offline   Reply With Quote
Old 03-15-06, 12:55 PM   #38
sockfocks
sockfocks's Avatar
If the engine ecu is able to, it will retard the timing and you will lose power and gas mileage (IS250 doesnt appear to do this). So the benefit of using regular octane to "save" money is lost in lower MPG. Besides....when you have to mash the pedal to get out of a situation, I want all my performance to save my behind...
Aircraft recip engines require 100 octane low-lead...would you want the pilot putting in 87-93 octane just to save money?
sockfocks is offline   Reply With Quote
Old 03-15-06, 12:59 PM   #39
Lets Drive
Lets Drive's Avatar
Quote:
Yep, most modern ECUs will just retard timing or do so when the knock sensors pick up detonation in order to prevent damage to the engine. I know the highest octane we get on this part of the east coast is 93, but other parts of the country see 91...neither will really harm the motor as its all engineered within its tolerance. However, with higher compression ratios or boost applications it makes sense to run higher octane fuels if its recommended.
Old 03-15-06, 01:13 PM   #40
tqlla3k
Damn, I cant beleive that people would put regular in a high performance car that says "Premium unleaded only"
The car requires it, and that should be enough. If you dont put in premium, you are not only lowering your performance, you are risking the life of your engine. You should also realize that lower octane gas than required may result in lower fuel efficiency. (I remember reading this somewhere, Something to do with the way the timing is retarded, though I dont have a source, if I am wrong, then I apologize)
So lets put it in perspective,
$2.40 for regular x 14 gallons
$2.60 for premium x 14 gallons = $2.80 or a little more than 1 gallon of gas.
23MPG on 93 = 322MPT
21MPG on 87 = 294MPT a difference of 28MPT, or a little more than 1 gallon of gas.
So in effect you didnt save anything, and you are risking the life of your engine.
You should also realize that when you switch from premium to Regular, you hurt your motor. Since the car has to realize its knocking before it adapts to the lower octane fuel.
tqlla3k is offline   Reply With Quote
Old 03-15-06, 01:20 PM   #41
OneOfOne
it amazes me that people would even consider not putting in the recommended fuel. I mean how stupid is it to worry about AT MOST an extra 3.40 more per tankful? thats assuming 20 cents more for 17 gallons. amazing.
OneOfOne is offline   Reply With Quote
Old 03-15-06, 01:23 PM   #42
sockfocks
sockfocks's Avatar
I quit looking at gas prices last year....too many worries..I put in 20-30 at a time and however far it gets me, so be it, then do it again....
Old 03-15-06, 01:29 PM   #43
Vmdc
Vmdc's Avatar
Well said tqlla3k Now that's something all of us can understand.
Premium Top tier for me in my IS and in my V-rod!
Vmdc is offline   Reply With Quote
Old 03-15-06, 01:33 PM   #44
rominl
exclusive matchup
rominl's Avatar
just as pointed, the cutting edge technology on the car (engine related) and the high compression, you need premium gas. normal gas will work, but you might get pinging and such, so why?
and like tqlla said, between premium and regular, gas mileage aside, with normal driving you might be spending 200 bucks more a yr..... that's for ONE YEAR. this is not against anyone (it's valid to ask these types of questions and understands why we need premium gas), but if someone says he needs regular gas coz' he's too cheap to pay for premium (all for that 200 bucks a yr), then personally i am not sure if he should have gotten this car....
rominl is offline   Reply With Quote
Old 03-15-06, 01:54 PM   #45
Lets Drive
Lets Drive's Avatar
Quote:
Actually, the cutting edge techonology is what allows people to run both regular and premium gas. The engines computer can adjust for both, and do so just fine at the sacrifice of a small bit of performance. Most premium brand makes though advertise premium gasoline because it coincides in most peoples minds as "better"...when in fact it just designates octane rating. A better car needs better gas is the idea, and it raises the hp level by a few digits on the window sticker. The myth is definately exploited for its lucrative properties rather than its practical ones showcasing real world results.
Unless the engine is using forced induction, I wouldn't say its the threat some are making it out to be, but for peace of mind people will go with whats recommended, even if its for marketing purposes. As I wrote above, premuim grade gasoline like 93 octane here is not available in other parts of the country. Todays engine has to be able to adapt.
Also the fuel mileage differences aren't going to be that radical...you'd sooner see worse MPG numbers though underinflated tires before you would be able to calculate anything from running regular. Conversely, you wouldn't get better gas mileage if your engine was designed for regular and you decided to run premium.
Thread Thread Starter Forum Replies Last Post
Regular or Premium Gasoline Required? sderman RX - 4th Gen (2016-present) 40 12-06-15 05:36 AM
ES 330/330 Regular gas or premium? Maineguy ES - 1st to 4th Gen (1990-2006) 4 02-06-15 08:09 AM
2008 rx350 gasoline CRHOPE RX - 2nd Gen (2004-2009) 4 12-04-08 02:07 AM
Gas Octane 2spark RX - 2nd Gen (2004-2009) 54 08-18-07 01:02 PM
Toyota hopes to cut hybrid premium in half Gojirra99 Lexus Prototypes and Next-Gen Technology 1 09-13-05 08:49 AM
Tags
2002, 430, 87, cruiser, es350, fuel, gas, georgia, is250, land, lexus, maxima, mileage, pennsylvania, premium, regular, worse
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
