Premium or Regular Gas ? - Page 2 - Club Lexus Forums
View Poll Results: What gas do you use ?
Premium 433 82.32%
Midrange 36 6.84%
Regular 57 10.84%
Voters: 526. You may not vote on this poll
Thread Tools Search this Thread
Old 03-14-06, 08:46 PM   #16
phish2112
phish2112's Avatar
Quote:
Originally Posted by bagwell
IS250: use of such gas wil cause persistant heavy knocking. If severe, this could lead to engine damage.
use of regular gas could cause engine damage!!!!!
phish2112 is offline   Reply With Quote
Old 03-14-06, 08:49 PM   #17
Vmdc
Vmdc's Avatar
Premium Top Tier all the way.. You can read about top tier here too
Top Tier Gasoline
Vmdc is offline   Reply With Quote
Old 03-14-06, 08:51 PM   #18
mjdart
I believe the IS250's compression ratio is 12 to 1 which is very high. Regular would be a stretch to get by without knocking.
mjdart is offline   Reply With Quote
Old 03-14-06, 09:38 PM   #19
GreyHound
GreyHound's Avatar
Quote:
Exactly. With the higher compression you need to have a more accurate explosion. 87 octane is more unstable as compared to 93 octane. In my Dodge Ram with the 'oldschool ' 5.9 engine, that 87 octane gas causes the valves to rattle, 'ping' exploding before the valve closes. I hate that sound, its just not right , metal against metal. 93 octane will smooth it out every time. So premium is not a question, its more of a requirement. I surely Hope the IS350 will get better mileage than a three quarter ton four wheel drive truck. It gets 16.5 on the highway, with a tailwind. About twelve and a half mpg pulling motorcycle trailer. So I won't feel too bad about using premium in IS350. You have to take care of your investment .
Oh, did I mention I pick up the car on Friday !
GreyHound is offline   Reply With Quote
Old 03-14-06, 09:53 PM   #20
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
I wonder if I use 110 octane racing fuel? Hmmm...
Might as well fill up the tank with Everclear.
PhilipMSPT is offline   Reply With Quote
Old 03-14-06, 10:42 PM   #21
05RollaXRS
Most of the Lexus cars should be fine with regular except Lexus IS 250/350 and GS300. These three cars use dual VVT-i and have extremely high compression ratios. Whether you use regular or premium is always determined by the compression ratio of the car. Ofcourse, it would not damage the engine in most cases if you use regular, but you will get constant knocking or if you drive it hard for too long with regular gas, it can seriously hurt the engine because low Octane gas mixed with gas cannot be compressed as well as high Octane with gas and can cause the fuel mixture to explode in the cylinder prematurely, which can lead to serious engine damage.
In a nutshell, Lexus IS and GS people should follow what the manual says and put premium in order to keep the car in best shape.
05RollaXRS is offline   Reply With Quote
Old 03-14-06, 11:11 PM   #22
tonyxcom
tonyxcom's Avatar
There is more to the required use of high octane gas then just compression. Timing advance also plays an important role. That being said, higher performance engines have more compression and timings that generally advance depending on throttle position and rpms.
Higher octane gas actually burns slower then lower octane, this is to help prevent pre-detination (aka knocking) as the air/fuel mixture is compressed in the cylinder.
Modern cars have knock sensors that can detect these pre-detinations and adjust air, fuel, and timing to compensate, but only to a certain extent.
I would never use 87, but the price difference between 89 and 91 is usually only 10cents per gallon which equates to less then $2 per fill up. Assuming you fill up once a week thats a difference about $110 over the year.
Why nickel and dime yourself over a $40K car?
tonyxcom is offline   Reply With Quote
Old 03-14-06, 11:53 PM   #23
emissivity
Here's a detail explanation on "octane ratings" http://en.wikipedia.org/wiki/Octane_rating
I will follow the recommended octane rating from Lexus 91 and above.
emissivity is offline   Reply With Quote
Old 03-15-06, 06:04 AM   #24
G35TOIS350
G35TOIS350's Avatar
Not a matter of "If you can afford the Lexus then why can't you spring for premium? Buy a Civic if you can't afford it". There are lots of things I don't buy but could easly afford. Why pay for the premium if you don't have to. My G35 only took premium so its no big deal to me. But I may run midgrade every now and then for my 70 mile commute.
G35TOIS350 is offline   Reply With Quote
Old 03-15-06, 06:07 AM   #25
TripleL
No Substitute
TripleL's Avatar
There is always lots of good points pro & con on this topic.
I tend to keep my cars for a long time. So to me, putting premium in as the manual requests seems like a simple enough request to follow.
TripleL
TripleL is offline   Reply With Quote
Old 03-15-06, 06:11 AM   #26
mcfly
Posts like this boggle my mind. You people need to do some research... Octane ratings aren't there for fun, and they're certainly not there to add to your vague notion that higher octane gas is in some way better, but really only something you splurge on.
Higher octane exists because it detonates less easily than lower octane. High compression means higher chance of detonation, hence the need for high octane fuel.
Obviously they're your vehicles, so do what you like. But the science and engineering behind Lexus's requirement for premium fuel is there for a reason.
mcfly is offline   Reply With Quote
Old 03-15-06, 09:09 AM   #27
RaZoRaMoN
Quote:
Originally Posted by blkIS350
You can use regular but you will just loose some performance. I, myself, will be using premium. My dealer actually delivers every new Lexus on their lot with regular. Ask them next time you are there and I would be surprised if most dealers deliver their cars filled with premium.
I was actually shocked to hear my salesperson tell me that they deliver all their cars with regular, but I can see them doing this to save a few dollars per car they sell.
The dealer I bought my car from also does this but I requested they put premuim and I know the tech that filled up my car and he did put premium.
My work pays for my gas so premium for my baby!
RaZoRaMoN is offline   Reply With Quote
Old 03-15-06, 09:16 AM   #28
jlin101
Quote:
Originally Posted by Aterrex
I guess. But Im cheap what can I say. I used regular in the Landcruiser for years even though it said premium. No problems there. But it is a landcruiser. Im not opposed to the idea. Just wondering if the book is always right.
that's like buying a $20k high-def plasma TV to watch low-res VHS, or feeding a thoroughbred crabgrass. No, it doesn't hurt it, but it defeats the purpose of buying a luxury, high-performance car in the first place. Basically you will lose "some" hp due to the lower octane. Occasional use is probably alright. How much money do you really save anyway, over the life span of this car, compared to the total cost of ownership?
jlin101 is offline   Reply With Quote
Old 03-15-06, 09:28 AM   #29
ahohnstein
ahohnstein's Avatar
Quote:
Originally Posted by phish2112
this is an interesting question. of course most everyone will initially fill her up with the top shelf, but in a few years that may become increasingly more difficult due to gas prices. I tend to put a ton of miles on my car from a long commute. If you add those extra few dollars up over the course of a year thats pretty substantial. hence going back to the posed question "how much could it possibly hurt to use regular gas?" I think thats a tough question to answer. for now...I'm all premium until convinced otherwise.
It's funny that you say that because for as long as I can remember premium has ALWAYS been 10 cents more than mid-grade, which is 10 cents more than regular. This is the case regardless of the fluctuations in the gas prices. Even when the gas $/gal nearly doubled it was 10/20 cents more than mid/reg. So, if this holds true, you could really say that as the gas pricess rise, premium becomes MORE affordable since the premium charged doesn't rise in relation to the gas price (percentage-wise)......
ahohnstein is offline   Reply With Quote
Old 03-15-06, 09:59 AM   #30
G35TOIS350
G35TOIS350's Avatar
Between my V8 Grand Cherokee, 73 Charger (9 miles a gallon on 110 octane), boat, commuter car, and the IS (once its delivered ) I pay out the rear for gas starting this time of the year thru October. Just one more thirsty toy in my eyes.
Thread Thread Starter Forum Replies Last Post
Regular or Premium Gasoline Required? sderman RX - 4th Gen (2016-present) 40 12-06-15 05:36 AM
ES 330/330 Regular gas or premium? Maineguy ES - 1st to 4th Gen (1990-2006) 4 02-06-15 08:09 AM
2008 rx350 gasoline CRHOPE RX - 2nd Gen (2004-2009) 4 12-04-08 02:07 AM
Gas Octane 2spark RX - 2nd Gen (2004-2009) 54 08-18-07 01:02 PM
Toyota hopes to cut hybrid premium in half Gojirra99 Lexus Prototypes and Next-Gen Technology 1 09-13-05 08:49 AM
Tags
2002, 430, 87, cruiser, es350, fuel, gas, georgia, is250, land, lexus, maxima, mileage, pennsylvania, premium, regular, worse
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
