Go Back   Club Lexus Forums > Lexus Model Forums > GX Models > GX - Second Generation
Sign in using an external account
Register Forgot Password?
Rusting Door Hinge Bolts
Thread Tools Search this Thread Display Modes
Old 04-06-15, 12:20 PM   #1
acas1229
Trader Score: (0)
Default Rusting Door Hinge Bolts
Howdy,
Due to the rain this weekend I decided to clean out my interior and do some maintenance. Lately my driver-side door has been making a squeaking sound. As such, I decided to lube up all the doors just in case. Upon inspecting all the doors/hinges I found that both the driver-side rear door and passenger-side rear door hinge bolts are rusted real bad. These are the bolts that connect the hinge to the door rather than the hinge to the door frame. Has anyone noticed this about their door/hinges?
I inspected the door for any sign of water intrusion, but could not see anything out of ordinary. Also, nothing else was rusted or appeared to be water damaged. I inspected all the other hinge bolts around the car for comparison and they were fine. It is strange that both rear passenger doors have this issue. I bought the vehicle used and the Carfax comes back clean with no accidents or damage reported.
The only other time I have seen this is when the door has been worked on, and a socket was used which stripped the protective paint off the bolt. Even then only the rough edges of the bolt rusted, and not the entire thing. While I could foresee one door being worked on, I do find it strange that both would have needed work. However, this assumption does not rule out the possibility.
My only other issue of concern which may play into this is the surprising amount of sand I find on the exterior. As good as one can clean a car there are always some places that will never get fully clean. With that said, while the exterior is clean I have found sand residue in little crevices (weep holes) and corners throughout. I am sure that sand and moisture would play a part in causing rust to accumulate, except that no other parts show any sign of rust. This is certainly bizarre to me. Any suggestions or comments would be greatly appreciated. I plan on replacing the bolts, but would like to remedy the problem before hand if possible.
Thanks - AC
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
acas1229 is offline   Reply With Quote
Old 04-06-15, 03:53 PM   #2
rockydog
Trader Score: (0)
All 4 of my door hinges are fine, no rust. Different story on the tailgate. Lifted the rear window and both hinges are significantly rusted.
rockydog is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
OK WTB: Black pass mirror, black driver door hinges Dx3 SC400 / 300 Classifieds 0 01-16-13 03:12 PM
Door hinge is tight on my 2008 LS 600HL. Is it easy to remove the hinge? lexus600hl LS460, LS460L and LS600h 30 12-27-12 09:21 AM
Door hinge bolts not painted? ALIGN ES350 and ES300h (2013+) 11 12-07-12 12:45 AM
RX Accident..Door got bent backward...help to find hinges or fix? Patsum RX - First Generation 7 06-17-10 12:13 AM
Used Car Inspection Checklist (please provide feedback) lexusman08 Car Chat 13 10-21-09 09:54 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
