First Project BMW OEM Led fogs
Old 01-04-15, 04:58 PM
Passat774
Passat774's Avatar
Lightbulb First Project BMW OEM Led fogs
I am going to give these a try in the OE fog light locations.
It looks like the should be a close fit and possibly can plug and play H11.
The mounting points may not be perfect but should be fair close.
http://www.theretrofitsource.com/clo...l#.VKnha_ldVUc
Tech Specs
Dimensions of Housing
Depth:131mm
Width:147mm
Height:142mm
Diameter (of bumper opening needed)95mm H x 102mm W (oval shape)
Dimensions of Internal Components
Depth:92mm
Width:85mm
Height:75mm
Diameter (of components from front):74mm H x 77mm W (oval shape)
Old 01-05-15, 05:03 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Very interesting and relatively affordable ... looking forward to seeing the results.
Old 01-05-15, 09:47 AM
T4Fun
T4Fun's Avatar
i thought about swapping out my leds for some brighter fogs, but these led fogs have
self leveling mechanism making them quite unique, so i kept them on. they are bright enough
for me. The led lights are like lasers at night. All signs are lit up in bluish hue. love it
Old 01-08-15, 09:09 AM
Passat774
Passat774's Avatar
I got the lights last night, it is going to be a retro fit no plug and play
Which I will still post the project and results
Old 01-10-15, 03:14 PM
Passat774
Passat774's Avatar
I did the retro fit today, it was not that bad. I had to take apart both the factor fogs and the BMW's. The BMW led internals fit inside our fog lights.
I will post pictures, looks factory and the output is nice, good color a little bluer than factory HID's
Old 02-07-15, 01:26 PM
Passat774
Passat774's Avatar
Here is a picture
Old 02-10-15, 01:52 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Looks good!
Any night time shots?
Old 02-10-15, 03:57 PM
Capirato
Capirato's Avatar
Where do I order a set ??
~ Cap
Old 02-10-15, 04:21 PM
tecman
tecman's Avatar
~ Cap
The link is still good.
http://www.theretrofitsource.com/clo...l#.VNqfz0c8KrV
Old 02-10-15, 05:17 PM
Passat774
Passat774's Avatar
I would only suggest doing this project if you have done a headlight retro fit or are a skilled craftsman
I had to cut apart the BMW lights completely and shave them down slightly. Then had to open the factory foglights and trim the internals of those as well.
Output of lights has always been a tough one for me, its hard to truly capture it. If you google these lights you can see the output.
Old 02-10-15, 07:56 PM
Capirato
Capirato's Avatar
OK, I have odered them. What else do I need to get ??
~ Cap
Old 02-11-15, 06:38 AM
Passat774
Passat774's Avatar
Nothing, just need to cut everything apart and install. Let me know if you need any help during the process.
Old 02-11-15, 09:56 AM
Capirato
Capirato's Avatar
Did you need to buy any bulbs and/or sockets ??
~ Cap
Old 02-14-16, 08:13 AM
Passat774
Passat774's Avatar
Selling these..... Cheap
Old 07-14-17, 08:10 PM
neelnaik
neelnaik's Avatar
Sorry for resurrecting an old thread, but the retrofit source makes LED projector fogs that are plug and play for our cars now. I thought I would update this thread in case anyone was looking for LED fogs.
https://www.theretrofitsource.com/as...to-xb-led.html
Acrad (07-15-17)
Quick Reply: First Project BMW OEM Led fogs
