Introducing Carista app for Lexus GX
Old 01-01-15, 07:26 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Originally Posted by Carista
Thanks I'll look into the mood light stuff, but I don't think there's a setting for that.
Theres currently an option to turn them on or completely off. Naturally they dim once the car is shifted out of park (foot-wells, door handles) but what id like to see is them saying in the full on position if possible effectively disabling the dimming operation.
GRAND_LS 4 is offline
Old 01-31-15, 07:07 AM
dmccombs
dmccombs's Avatar
The beta for iOS is going on. Has anyone here tried it yet?
I get my WiFi ELM327 adapter today, so I wanted to make sure the beta wouldn't make my GX spontaneously combust, or randomly change settings that I already like.
For folks with the android or IOS beta, what settings did you change, that you can't already change through the on-screen menus?
dmccombs is offline
Old 01-31-15, 12:14 PM
Carista
Former Sponsor
Carista's Avatar
Hi,
The customizations in our iOS version are exactly the same as in our Android version - so we don't expect any spontaneous combustion
But yeah, please give it a try and let us know how it goes
Carista is offline
Old 01-31-15, 02:51 PM
dmccombs
dmccombs's Avatar
Carista,
The app seems to list all the LPS settings. Most of them, we can already get at via the nav screen setup menus. On the 2014-2015 GX, there are about 10-11 settings are Dealer Only settings. I guess this is what we need this app for, correct?
It takes about 3 minutes for the software to read the Lexus settings, but then you can scroll through the settings and make changes quickly. The app seems to be working as it should.
dmccombs is offline
Old 02-06-15, 01:39 PM
dmccombs
dmccombs's Avatar
I just downloaded the updated beta, and it has some nice improvements. The sync with the car is now closer to 2 minutes. They also added a feature where you can email your car settings. I think this is very handy.
Below is what you get in an email, from the GX.
Doors / Windows / Remote
Blink turn signals when locking/unlocking with remote
*YES* / NO
Beep when locking/unlocking with remote
*YES* / NO
Volume of beep when locking/unocking with remote
OFF / 1 / 2 / 3 / 4 / 5 / 6 / *MAX*
Beep when opening/closing windows with remote
*YES* / NO
Warn when door can't be locked with remote because it's open
*YES* / NO
Panic function on remote
*ENABLED* / DISABLED
Open glass hatch via remote
SINGLE CLICK / DOUBLE CLICK / *LONG PRESS* / VERY LONG PRESS / DISABLED
Re-lock doors automatically if you unlock, but don't open a door
*YES* / NO
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / *60 SECONDS* / 120 SECONDS
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Unlock doors via physical key
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Unlock doors via smart key (door handle button)
Auto-lock doors when moving
*ON* / OFF
Lock doors when shifting into gear
ON / *OFF*
Unlock doors when shifting into park (P)
*ON* / OFF
Unlock all doors when driver's door is opened
ON / *OFF*
After locking with smart key, allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
Smart key location to start car
FRONT SEATS / *ANYWHERE IN VEHICLE*
Open glass hatch via smart key
*YES* / NO
Open windows and sunroof by holding key in door lock
*ON* / OFF
Close windows and sunroof by holding key in door lock
*ON* / OFF
Open windows and sunroof via long-press on remote
*ON* / OFF
Instruments / Display / Dings
Seat belt warning ding (driver)
ENABLED / *DISABLED*
Seat belt warning ding (front passenger)
Remote low battery warning
*ON* / OFF
ECO Drive indicator zone
*ON* / OFF
Lights
Daytime running lights
*ON* / OFF
Coming-home lights duration
OFF / *30 SECONDS* / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
Automatic High-beam System (AHS)
Instrument lights dimming sensitivity
Instrument lights restoring sensitivity
Dim interior lights after…
7 SECONDS / *15 SECONDS* / 30 SECONDS
Turn on interior lights when you shut off engine
*YES* / NO
Turn on interior lights when you unlock doors
*YES* / NO
Turn on interior lights when smart key in range
*YES* / NO
Interior footlight (bright when doors open, dim when driving)
*YES* / NO
Center console spotlight (bright when doors open, dim when driving)
*YES* / NO
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
*YES* / NO
Turn on exterior footlight (on side mirror) for…
OFF / 7 SECONDS / *15 SECONDS* / 30 SECONDS
Turn on scuff plate light when smart key in range
*YES* / NO
Turn on scuff plate light when doors unlocked via remote
*YES* / NO
Turn on scuff plate light when driver's door is opened
*YES* / NO
Interior light control
Exterior light control
Other
Slide driver's seat back for easy exit
OFF / SHORT / *STANDARD*
Obtained with Carista 100006 for iOS.
dmccombs is offline
Old 02-08-15, 08:46 AM
craigrpete
craigrpete's Avatar
Default I Like Carista!
I'm in the beta program and wanted to give some feedback here.
I bought the VGate iCar3 WiFi adapter to use with my iPhone 5s. Goes for about $35. The OBD2 port is right under the dash by the steering column. No access issue at all. Easily paired to my iPhone: I "forgot" my normal home wifi network and connected to the V-Link network the adapter broadcasts on the first try. Easy. This adapter is supposed to power itself down so you can leave it plugged in for an extended period without worrying about draining the car battery but I havent tried that yet.
Carista performs two main functions. I tried both checking for any diagnosic codes as well as checking/changing some customizable settings. First it takes several minutes with the adapter above to check diagnostics. The Carista app gives you a reasonable percentage complete indication so you know it's doing work. One strange thing I noticed was the nav displays a diagnostics screen you can't normally get to. I didn't play with those menus but want to explore them later. When the process is complete you can just easily exit out of those menus on the nav unit. Since I didn't have any check engine/dash lights on to start with I didnt do anything more with this function.
Second thing I did was get into the settings function in the Carista app. It took Carista with the VGate adapter about 2 minutes to gather all my settings before displaying them. I can confirm it did allow me to view and set both customer as well as dealer-only settings! In my case I turned off the seat belt ding sound which is normally a dealer-only option. Saving settings took just a couple seconds. My opinion is it's great to have all these options in one place, easily scrollable on your phone vs. the nav interface. And as an added bonus you can have the app email you your settings!
In short, Carista is well worth the $20 - I give it 4 stars! And I think everyone will want an OBD2 adapter if for no other reason than to just look up engine light codes that we all invariably experience at some point. In fact the check engine light on my my Gen 4 2005 4Runner had come on the day I decided to buy the adapter and give Carista a try so I'm getting immediate additional use.
craigrpete is offline
Old 02-08-15, 12:46 PM
tecman
tecman's Avatar
I still can't play.
tecman is offline
Old 02-08-15, 02:28 PM
Eppieguy
Eppieguy's Avatar
You've been a very bad boy!
Eppieguy is offline
Old 02-09-15, 10:03 PM
Somun
Somun's Avatar
Default Dongle problems
I picked up the dongle from Amazon (same as an earlier poster mentioned).
I was able to pair to my Android phone just fine, but the Carista app says that my OBD device is defective. While that could be a true statement (I did only pay $10), that error description is rather lacking.
Any more details about the failure that could be extracted would be helpful. Debug log, error codes, etc...
Somun
Somun is offline
Old 02-10-15, 05:09 AM
Carista
Former Sponsor
Carista's Avatar
Somun
In the latest version of Carista, we added some logic to detect these bad devices that are flooding the market. So if the app shows you that message, that means it has detected that your device falls in that category, sorry. Outside appearance is not indicative of the quality of the device - we've seen lots of cases where 2 devices look the same, but one works and the other doesn't. If you're interested in finding out technical details of why we think your device is bad, please send us a debug report through the app and we'll be happy to forward you the log. Thanks.
Carista is offline
Old 02-10-15, 09:53 AM
Somun
Somun's Avatar
Since the cheap version of the OBD2 reader was defective (might have just been the unit I purchased), it would be good to know what specific qualities I should look for in a replacement unit.
Somun
Somun is offline
Old 02-10-15, 03:25 PM
SilverLady
SilverLady's Avatar
Thanks for doing something for the Android! Tired of Iphone apps with crummy porting a day late and a dollar short...
SilverLady is offline
Old 04-11-15, 03:15 PM
stubble
stubble's Avatar
I'm thrilled with this! bought the app and the
iKKEGOL wifi dongle iKKEGOL wifi dongle
from Amazon. Worked like a charm on my 2011 GX460. I am thrilled to have the all-windows-down feature enabled on my fob now!
Thanks Carista folks.
stubble is offline
Old 04-11-15, 04:36 PM
tecman
tecman's Avatar
Thanks for the reminder. I downloaded the app and ordered the same dongle.
I ordered an OBD2 splitter due to I installed a GPS tracker on my GX (personal use, not insurance company). Hopefully no conflicts between the two devices.
Amazon.com: Ultra Low Profile Left or Right Angle OBD II 2 Y Splitter Cable 30cm/12": Automotive Amazon.com: Ultra Low Profile Left or Right Angle OBD II 2 Y Splitter Cable 30cm/12": Automotive
tecman is offline
Old 04-13-15, 06:37 PM
Carista
Former Sponsor
Carista's Avatar
Somun
There are lots of fake Bluetooth ELM327 devices out there. In the US, we recommend the BAFX device that we link to here: http://www.caristaapp.com/hardware/?platform=android
Yup, we love Android too But actually, Apple was the one that shot themselves in the foot by disallowing standard Bluetooth data communication. That's the main reason why we went with Android first. Since then, WiFi OBD devices have appeared and their prices have gone down significantly, so now there's an option for those iOS users as well
Originally Posted by stubble
I'm thrilled with this! bought the app and the iKKEGOL wifi dongle from Amazon. Worked like a charm on my 2011 GX460. I am thrilled to have the all-windows-down feature enabled on my fob now!
Awesome
I would recommend turning off any other OBD devices when you use Carista (or any other OBD app, really). The OBD2 protocol was designed with one "tester" device in mind, and if you have multiple ones, you will most likely get interference, especially from the point of view of the ELM327 devices that Carista uses. So yes, either turn off or entirely unplug your GPS tracker when you use Carista.
Carista is offline
hzhao
GX - 2nd Gen (2010-2023)
167
08-31-21 05:58 PM
Carista
CL Vendor Products for 4GS
134
11-25-16 05:40 AM
SilverLady
113
11-02-16 05:37 AM
jruhi4
GX - 1st Gen (2004-2009)
03-30-07 11:01 AM
Quick Reply: Introducing Carista app for Lexus GX
