Where to buy Rims
Old 07-15-14, 02:10 PM
Lolrax
Lolrax's Avatar
Here is white GX I found on a dealer lot with some 22s. White on white!
Attached Thumbnails Where to buy Rims-rims1.jpeg   Where to buy Rims-rims2.jpeg
Lolrax is offline
Old 07-15-14, 02:58 PM
tecman
tecman's Avatar
I like it when white (or the car color in general) is integrated into the wheel. A solid white wheel is to much for me and I have seen many painted wheels peel. I considered having some black painted on my wheels and was told the cost was $250 per wheel no matter how much I had painted because of the process.
tecman is offline
Old 07-15-14, 05:10 PM
tecman
tecman's Avatar
http://www.cecwheels.com/Default.asp...allery-results
Attached Thumbnails Where to buy Rims-03-img_8734.jpg   Where to buy Rims-9-img_0389.jpg   Where to buy Rims-p1200887.jpg   Where to buy Rims-p1250369.jpg   Where to buy Rims-8741653894_b478487a4f_z.jpg
tecman is offline
Old 07-15-14, 05:26 PM
T4Fun
T4Fun's Avatar
i am waiting for KHANN wheels to arrive in US when they get a dealer set up.
by far, these new dux 10s are the best design yet.
http://www.khann.ru/products/dux-10
T4Fun is offline
Old 07-15-14, 05:44 PM
tecman
tecman's Avatar
Nice, will the US dealer come anytime soon?
tecman is offline
Old 07-15-14, 07:10 PM
Lolrax
Lolrax's Avatar
Those are hot!
Lolrax is offline
Old 10-26-14, 05:04 PM
tecman
tecman's Avatar
http://originalwheel.com/lexus/gx-460.html
If you are looking for used factory wheels.
tecman is offline
Old 10-16-15, 07:13 AM
Khann
Khann's Avatar
you can order them in Russia with delivery to USA
Khann is offline
Old 10-16-15, 08:40 AM
M1911
M1911's Avatar
I'm absolutely not a fan of 20" or larger wheels -- they are heavier, more fragile, expensive, and the tires are more expensive as well. As a result of the heavier weight and shorter sidewall, ride is worse as well. And I don't care for the look either. The only advantage of a larger wheel is that you can go to a larger diameter brake rotor, which will be less likely to fade under heavy use.
Be that as it may, one advantage of the GX 460 is that the bolt pattern is the same as all the Toyota trucks. 4Runner, Land Cruiser, LX570, Tacoma, Sequoia, and Tundra wheels will all fit the GX 460.
M1911 is offline
Old 10-16-15, 09:45 AM
Khann
Khann's Avatar
The GX has different bolt pattern from the rest of the SUVs
Khann is offline
Old 10-25-15, 12:32 PM
echong
4th Gear
echong's Avatar
Which is the perfect size for 20"? tires and wheels
echong is offline
Old 10-26-15, 12:02 AM
Khann
Khann's Avatar
R20 265/50
Khann is offline
Old 10-29-15, 02:17 PM
epoy
epoy's Avatar
My new rims and tire.
epoy is offline
Old 10-29-15, 04:26 PM
tecman
tecman's Avatar
Nice, what exactly do you have? Is that a two piece rim?
tecman is offline
Old 10-29-15, 10:00 PM
epoy
epoy's Avatar
Its FK ethos lxm rims
epoy is offline
Lyla1218
05-14-17 03:03 PM
Hill60
GX - 1st Gen (2003-2009)
28
03-11-14 12:14 PM
pearllex09
01-30-12 04:16 PM
pc93
04-10-11 07:31 PM
mannye
05-04-10 09:12 PM
Quick Reply: Where to buy Rims
