GX460 wheels on a '05 GX470
Old 04-22-14, 07:38 PM
pbsabo
pbsabo's Avatar
Default GX460 wheels on a '05 GX470
Will "luxury" wheels off a 2014 GX460 fit a 2005 GX470? They measure 18 x 7.5 and are the split six spoke style. Also, does anyone know what the offset is for these wheels? I currently have the stock 17 x 7.5 wheels and I was told their offset is 25mm. Correct?
Any input would be appreciated.
pbsabo is offline
Old 04-22-14, 07:52 PM
Lolrax
Lolrax's Avatar
They will fit no problem
Lolrax is offline
Old 04-22-14, 09:39 PM
KVA
KVA's Avatar
Just measured and the offset for the 2014 GX wheels are +38MM (or 1.5"). The backspacing is 5.25".
Note that I had a 2006 GX and the brakes are identical so clearance is OK. Wheel diameter is fine as I had the same total diameter setup on my older GX. Calculate the stock 18's on 265/60R18 30.52 vs. 265/65R17 at 30.56 (which I ran)
Technically, +38 will bring the wheel more inside the wheel well (towards the upper control arms) than a +25. My current +0 setup is slightly outside the wheel well - think farther away from the brake caliper.
These should work no problem, your basically talking about a 1/2 inch difference in offset from the stock 17's.
KVA is offline
Old 04-23-14, 05:11 AM
dstock
dstock's Avatar
I have a cheap set of OEM 2011 w/ wheel locks and lug nuts on eBay right now if you're interested. They fit also. $600.
dstock is offline
Old 04-23-14, 06:09 AM
Eppieguy
Eppieguy's Avatar
2005 is 5 lug, 2010-2014 is 6 lug. You'll need wheel adaptors.
Eppieguy is offline
Old 04-23-14, 06:17 AM
T4Fun
T4Fun's Avatar
all gxs are 6 lug nut. there is no 5 lug rim that exists, well, not in US atleast
T4Fun is offline
Old 04-23-14, 07:57 AM
Eppieguy
Eppieguy's Avatar
I stand corrected.
Eppieguy is offline
Old 04-24-14, 07:51 AM
RoseLex
RoseLex's Avatar
They will fit no problem. However you will need to swap the TMPS from the GX470 or have the ones from the GX460 reprogrammed. Here's a pic of ours just scroll down to the last post.
https://www.clublexus.com/forums/gx-...ml#post7957861
RoseLex is offline
Sackett98
GX - 1st Gen (2004-2009)
23
11-22-20 09:52 AM
Matsui
10-21-15 05:39 AM
zippinbye
11-05-10 11:09 AM
Quick Reply: GX460 wheels on a '05 GX470
