"P"275-65-18 LTX MS2's
Old 02-19-14, 11:17 AM
Eppieguy
Eppieguy's Avatar
Default "P"275-65-18 LTX MS2's
I ordered the "P" version of the above tire because I wanted to retain a nice soft ride and the most I'll ever tow is a Motorcycle and that will be very rare. I ordered them from Costco with no issues at all. They asked me what they were going on and advised me that they are bigger then OEM specs, I told them I know they will fit and there was no further conversation. They will be in tomorrow and I'll try to get them installed tomorrow if I get a chance. I'll post pictures when I can.
Eppieguy is offline
Old 02-19-14, 11:34 AM
Eppieguy
Eppieguy's Avatar
As it sits today (Buried in the snow for 3 weeks, hasn't moved)
Attached Thumbnails "P"275-65-18 LTX MS2's-photo-3.jpg   "P"275-65-18 LTX MS2's-photo-2.jpg   "P"275-65-18 LTX MS2's-photo-1.jpg
Eppieguy is offline
Old 02-19-14, 12:17 PM
Revnitup
Revnitup's Avatar
That's crazy! Great Pics. Can't wait to see it with a size up in tread to.
Revnitup is offline
Old 02-19-14, 12:30 PM
Eppieguy
Eppieguy's Avatar
That's after a few days of melting snow, was much worse. I have been driving a 2010 GS AWD and I have to say that it's handled the snow ok, I wouldn't have wanted to drive through an unplowed parking lot but it did fine on traveled snow packed roads.
Eppieguy is offline
Old 02-19-14, 02:52 PM
SpokeBroke
SpokeBroke's Avatar
I would have done the same thing, but I thought Costco would not allow it, so I got the LTX MS2's in OEM size. They are great. Will you need to replace the spare as well to match the tires?
SpokeBroke is offline
Old 02-19-14, 03:31 PM
Eppieguy
Eppieguy's Avatar
I'm not going to replace the spare since I don't have a matching wheel for a spare. I'm not too concerned about the difference in size for a short trip to get a tire repaired due to a flat and I have another vehicle if it proves to be a longer process for some reason.
Eppieguy is offline
Old 02-19-14, 04:01 PM
SpokeBroke
SpokeBroke's Avatar
That makes sense. Please post photos - they will look great.
Old 02-20-14, 01:50 PM
Eppieguy
Eppieguy's Avatar
Mounted and balanced, drove it a 1/8 if that of a mile back to my office and parked it again. I won't be driving it until March 1st. so I won't be able to give a review of how it drives until then but it sure felt better driving it across the parking lot! Pictures don't do it justice but to the naked eye it sure looks better to me. First picture is profile of OEM tire, Sencond is obviously new tire.
Attached Thumbnails "P"275-65-18 LTX MS2's-photo-1.jpg   "P"275-65-18 LTX MS2's-photo-2.jpg   "P"275-65-18 LTX MS2's-photo-3.jpg   "P"275-65-18 LTX MS2's-photo-4.jpg   "P"275-65-18 LTX MS2's-photo-5.jpg
Eppieguy is offline
Old 02-20-14, 03:58 PM
SpokeBroke
SpokeBroke's Avatar
That looks great. Visually, it fills out wheel wells.
Old 02-20-14, 04:23 PM
Eppieguy
Eppieguy's Avatar
Here is a shot of when I tried to take it over to Costco, it didn't want to go.
Eppieguy is offline
Old 03-03-14, 12:58 PM
Eppieguy
Eppieguy's Avatar
UPDATE..... I've finally been driving it with the new tires for a few days and I rub. It's rubbing on the bolt on the inner fenderwell. It's the top bolt the connects the black running board flap to the inner fenderwell. It also looks like I'm rubbing a little at the bottom of the running board on the passenger side too. It's only on off camber turns, like pulling on to a driverway apron while the wheel is turned. Not sure why I am rubbing and others aren't, maybe because I got the "P" tires and not the "E" so there's more sidewall flex. It's not all that bad, I just have to be a little careful and I'll get it re-adjusted once it warms up a little. Just a little bumming because others reported no issues.
Eppieguy is offline
Old 03-03-14, 09:31 PM
frank69m
frank69m's Avatar
This is odd. The difference between a 275 and 265 should be so minor. Although, it should be a tad taller of a tire also.
frank69m is offline
Old 03-04-14, 04:33 AM
Craig B
Craig B's Avatar
Just curious, why didn't you go with the recommended size? Will Costco swap them out for the recommended size?
Craig B is offline
Old 03-04-14, 05:49 AM
Eppieguy
Eppieguy's Avatar
I thought the OEM tire looked lost in the fenderwell and KOZ reported that they fit (He ran the "E" load range though) and I just think it looks a lot better with a taller and wider tire. Yes, Costco put them on, they questioned the difference in size, I told them I knew they would fit and then they told me they won't be better in the snow than OEM size due to being a wider tire and I told them I was ok with that and that was the end of the discussion. It is quiter and rides so much nicer than the OEM tires. I'll get the rubbing handled once it warms up a bit and I can see what adjustments I can make, it's not my first time with stuffing tires and having rubbing issues.
Eppieguy is offline
Old 03-04-14, 06:20 AM
Quadro
Quadro's Avatar
If I recall correctly Koz had to take a heat gun to the fenders to avoid rubbing. But he had no choice since he wanted E rated tire. That was the main reason I've got OEM size MS/2 (P rated).
Quadro is offline
Quick Reply: "P"275-65-18 LTX MS2's
