Body on Frame vs. Unibody Discussion Continued
Old 10-05-13, 02:50 PM
  #46
Received 2,521 Likes on 1,819 Posts
That's all they have over there. You talk as if these people have made a conscious choice between a BOF vehicle and a unibody vehicle. There's no choice. They have no safety standards, their consumers have no need for comfort or design, they just need utilitarian vehicles, hence why sell anything but old, basic, BOF vehicles there?
You're drawing a conclusion when there isn't enough evidence there to support it.
SW17LS is online now
Old 10-05-13, 03:31 PM
  #47
Quadro
Quadro's Avatar
What do you mean no choice? Middle East, Africa, Russia, Australia -- you can buy crossover SUVs in any of these places! I would hardly call the LX/GX to be utilitarian vehicle with no comfort! Top Prado trims are very nice too.
Quadro is offline
Old 10-05-13, 07:01 PM
  #48
FrigginFGO
FrigginFGO's Avatar
If I needed to go far into the bush offroading, there are whole bunch of vehicles I would take over the GX. A basic 4Runner with a mechanical 2H/4L lever will be superior to the electronic dash switch in the GX. Also, the GX adaptive variable suspension and KDSS will have more stress and fail points than a 4Runner with a basic nuts and bolts set up.
Not to sure about Cherokee but my thoughts are is that they are highly electronic like the GX.
Can you imagine the GX electronic transfer case malfunctioning while in 4L with a malfunctioning adaptive variable suspension stuck in the low position. No thanks.
What makes you think the lever will be superior to the switch? Both can could have malfunctions. I can agree with you about the suspension, but that's why the Lexus offers a GX without the air suspension. And this generation of 4Runner is laughable at best. It has all the added weight with no V8 option. Also KDSS has been available since previous generation GX and I have yet to read a failure on the system, especially those who off road them.
FrigginFGO is offline
Old 10-05-13, 08:34 PM
  #49
You're bouncing back and forth from talking about military and war use in Afghanistan and talking about places like Australia.
Old 10-05-13, 09:29 PM
  #50
I don't claim toughest. Where did you see that? But I claim they are used far harder than any unibody Jeep is. The premise here is if a unibody SUVs were as capable you would see them equally used (or even beat) body-on-frame SUVs. Did you just say 4WD Ford trucks and not Ford crossover SUVs by any chance?
You are missing the point of the whole discussion, it is not the design BOF vs unibody that is most important, what is important is the engineering of the vehicle.
A unibody can be just as durable and good as a BOF. The Toureg and the Range Rover are both rated to haul and tow more than the GX460.
Google "unibody vs frame" and you will see a 50s Chevy BOF get destroyed by a 2009 Chevy unibody.
From what everyone is saying in this thread, the body on frame is safer in a crash. ????
Toys4RJill is offline
Old 10-05-13, 09:42 PM
  #51
The whole point of the switch vs the electric actuator is that there is mechanical hard link connected from your hand which is directly linked to the transfer case. No electronics to fail, no plastic switch to break. From a durability point of view, the lever will be superior.
The 4Runner will eat the GX for lunch off the beaten path. Design wise, less things to go wrong on a basic 4Runner than a GX. Just imagine what would happen to the big bad GX if the AVS failed, the 4lo actuator failed, perhaps the crawl control was stuck on the on position or what would happen if the power telescoping steer wheel was stuck too in the low position rendering the GX undrivable?
From an engineering standpoint , the 4Runner should be superior.
And the Prado uses the same V6 as the 4Runner.
Old 10-06-13, 06:40 AM
  #52
FrigginFGO
FrigginFGO's Avatar
The 4Runner isn't superior. Even the 1st Generation GX had more torque than 4th generation 4Runner V8 and 5th Generation V6. You are naming issues that aren't known issues with the GX with the exception of the electronic 4wd actuator. And that actuator issues is because most people don't throw in in 4Lo regularly like they should per the owners manual. It's an easy fix, usually a few hits with a rubber mallet on the system underneath to get it going. But the lever can have issues too. The doors and hood on the 5th generation 4Runner are made with extremely thin sheet metal, and those owners report seeing hood movement while driving. There is absolutely no way that 4Runner is superior except its price.
Old 10-06-13, 06:48 AM
  #53
FrigginFGO
FrigginFGO's Avatar
The Toureg was one of the least reliable vehicles ever made.
http://www.volksbloggin.com/2006/08/...-cars-of-2006/
Old 10-06-13, 07:56 AM
  #54
Quadro
Quadro's Avatar
Did you read the whole thread? We already went through it. The rating is determined by NHTSA and doesn't mean the vehicle is going to hold up towing it's required rating for a number of years.
A crash is a game of numbers. A heavier car will always have an advantage in a vehicle vs vehicle collision. What NHTSA measures is a crash with a concrete wall, which by the way, puts heavier cars at a disadvantage because all this energy has to be absorbed by the car itself. When LX hits a Telsa in a head-on collision I don't care what NHTSA rating the Tesla has -- I want to be in the LX because it'll simply throw Tesla off the road without taking much impact itself.
Quadro is offline
Old 10-06-13, 08:01 AM
  #55
Wow, you really are not sure of what makes an off road vehicle worthy, the 4Runner Trail Editions 33/26 approach/departure angles are far superior to the GX's 28/25. Also, the 4Runner has 1.5 inches more ground clearance than the GX. Lets also not forget that the GX is 400 lbs lighter than the GX.
Old 10-06-13, 08:02 AM
  #56
Quadro
Quadro's Avatar
Are you kidding? I wasn't the one who brought Afghanistan into the discussion. I'm not bouncing anywhere. The entire Toyota/Lexus SUV trucks lineup sells in huge numbers worldwide -- that's not because people who buy them have no choice but because they actually need them. You can walk into the Toyota Dealership in Russia (for example) and you can walk out with a Toyota Highlander or you can walk out with the Prado which is substantially more expensive vehicle. There are way more Prados in Russia than Highlanders because people need this vehicle's capabilities.
I think LX gets even more bashing in the US for it's truck roots than GX does. Guess what -- it's a number #1 Lexus model sold in the Middle East. It outsells everything else, including the RX. It's a huge success overseas.
Quadro is offline
Old 10-06-13, 08:08 AM
  #57
Quadro
Quadro's Avatar
Wow, you really are not sure of what makes and an off road vehicle worthy, the 4Runner Trail Editions 33/26 approach/departure angles are far superior to the GX's 28/25. Also, the 4Runner has 1.5 inches more ground clearance than the GX. Lets also not forget that the GX is 400 lbs lighter than the GX.
First of all you should be comparing 4Runner to a Prado. A Prado has 32/25 so it's really a wash. The lower approach angle on the GX is simply caused by a bigger bumper, that's it. Secondly in the parts of the world where people can buy both Prado is generally considered to be superior and is more expensive.
Quadro is offline
Old 10-06-13, 08:25 AM
  #58
Why are you so focused on whether a vehicle is more expensive or not? That makes no difference.
Old 10-06-13, 08:34 AM
  #59
Quadro
Quadro's Avatar
You can't sell a more expensive vehicle which brings no additional value other another cheaper model.
Quadro is offline
Old 10-06-13, 08:51 AM
  #60
What are you trying to get at? The GX/4Runner/Prado and FJ are essentially the same vehicle. The GX is a rebadged Prado and the 4Runner is a V6 Prado with a different body.
Quick Reply: Body on Frame vs. Unibody Discussion Continued
