Michelin LTX® M/S2
Old 10-10-13, 05:30 AM
MickeyS
MickeyS's Avatar
Wow, I can now say that there is an overwhelming support for this tire as the best tire for our GX. I can't wait to put them on my GX. If you are kind enough, can you post some pics of your GX with them on to see how they look, Thanks!
MickeyS is offline
Old 10-10-13, 06:33 AM
Koz
Koz's Avatar
Keep in mind, these are LTs (up to 80psi) and are about a size bigger then OEM.
https://www.clublexus.com/forums/7556686-post45.html
Koz
Koz is offline
Old 10-10-13, 09:21 AM
MickeyS
MickeyS's Avatar
Koz
So basically the tire is the same size as the OEM(265/60/18) or I have to order a different size? Or is bigger because it has more threads than the OEM?
MickeyS is offline
Old 10-10-13, 09:49 AM
Quadro
Quadro's Avatar
The problem is MS/2 LT does not exist in OEM size. There is MS/2 passenger tire which does exist in OEM size and seems to fare better in the reviews as well (compared to OEMs) but it lacks Green-X technology the LT tire has and is also rated for a far lower pressure than 80 psi.
Quadro is offline
Old 10-10-13, 10:19 AM
Craig B
Craig B's Avatar
Tire Rack has them in LT OEM size.
Craig B is offline
Old 10-10-13, 10:45 AM
Quadro
Quadro's Avatar
Link? I was never able to find them...
Quadro is offline
Old 10-10-13, 11:05 AM
Koz
Koz's Avatar
If you do not tow and/or carry heavy loads you do not want or need LTs, get the "P" rated tires. Also, LTs do not come in the OEM size (265/60/18), the "P" rated tires do . The closest size in the LTs are 275/65/18 and they have a 1.6' larger overall diameter (approx 32" tall).
Koz
Koz is offline
Old 10-10-13, 11:44 AM
Craig B
Craig B's Avatar
Koz
Michelin LTX A/T 2
On-/Off-Road All-Terrain
Consumer Rating
Warranty Rating
Sidewall Style: Outlined White Letters
Serv. Desc: 109T
UTQG:
500 A B
Price: $224.00 (each) Special
Estimated Availability: In Stock
Estimated Arrival: Get Estimate
I see them at http://www.tirerack.com
Craig B is offline
Old 10-10-13, 11:59 AM
Quadro
Quadro's Avatar
No, look at the specs -- P265/60R18, the P in front means it's a passenger tire.
The one Koz is talking about would be LT265/60R18 which does not exist.
Quadro is offline
Old 10-10-13, 12:00 PM
Koz
Koz's Avatar
Michelin LTX A/T 2
Consumer Rating
Warranty Rating
Serv. Desc: 109T
UTQG:
500 A B
This is not the same tire (completely different type of tire) and nowhere near as good and will last half as long!
Koz
Koz is offline
Old 10-10-13, 12:05 PM
Koz
Koz's Avatar
If you want an AT tire, the Goodyear DuraTrac is the weapon of choice and they are great in snow.
Koz
Koz is offline
Old 10-10-13, 12:55 PM
Craig B
Craig B's Avatar
Koz
Okay thanks, I will stick with the OEM Michelins...
Craig B is offline
Old 10-10-13, 01:20 PM
Quadro
Quadro's Avatar
You can get P-rated OEM size LTX MS/2 which has the same wear rating as LT and better reviews than OEM.
Quadro is offline
Old 10-10-13, 02:30 PM
MickeyS
MickeyS's Avatar
I'm planning to get them at the local Mavis tires. When I order them what size or basically how do I order them? I'm not towing and all my driving will be city and highway.
MickeyS is offline
Old 10-10-13, 03:38 PM
Received 2,520 Likes on 1,818 Posts
You don't need an LT tire on the GX. My experience with the LTX lasting over 100k miles is with the normal "P" tires.
SW17LS is offline
Quick Reply: Michelin LTX® M/S2
