Oil Change : independent mechanic and warranty
Old 02-12-13, 01:21 PM
sv1669
sv1669's Avatar
Default Oil Change : independent mechanic and warranty
anyone knows for sure if the warranty is affected in case if I service my car at independent mechanic. Considering they are very experienced, right type of oil, everything is right - these guys are around for long time and 100% feedback, and lots of ppl with Lexus service their cars there - basically it is even better and cheaper than at Stealership. Any cases Lexus refused warranty repairs due to service place choice????
sv1669 is offline
Old 02-12-13, 03:31 PM
Koz
Koz's Avatar
Not to worry; the only way you will have warranty issues is if any work or part causes a failure and Lexus can prove it.
Koz
Koz is offline
Old 02-12-13, 03:52 PM
Craig B
Craig B's Avatar
I would have them use the factory oil filter and drain plug gasket that can be purchased from any Toyota dealership. I would also use 0W20 synthetic oil as well. If you have a record of it, there won't be any problem using an independet shop. I live 120 miles each direction from my Lexus dealer and take mine to my local Toyota dealer for oil changes unless I need other service from the Lexus dealership.
Craig B is offline
Old 02-12-13, 04:52 PM
sv1669
sv1669's Avatar
excellent!!! thanks you guys!
sv1669 is offline
Old 02-13-13, 08:26 AM
patgilm
patgilm's Avatar
The only benefit to me of going to the dealership for routine maintenance is that they will goodwill certain things if something breaks or is a problem that is not under warranty.
patgilm is offline
Old 02-14-13, 11:48 AM
Koz
Koz's Avatar
If anyone has changed the oil, you know what a PITA the filter is. This tool should help a lot. I purchased one but have not used it yet. Looks pretty good for $20.
https://www.clublexus.com/forums/is-...-this-out.html
Koz
Koz is offline
BB11
05-08-17 11:24 AM
Courtez
Canada
20
07-21-12 04:41 AM
bragado
ES - 5th Gen (2007-2012)
10-06-10 06:03 AM
Quick Reply: Oil Change : independent mechanic and warranty
