LT Tires on GX460
Old 06-21-13, 10:28 AM
  #91
Koz
Koz's Avatar
Originally Posted by mitsuguy
Unfortunately that doesn't surprise me, just makes more business for me... In this day and age anyone can sue for any reason, or even no reason at all.
Id personally patronize the places that haven't gotten quite that crazy...
I totally agree!
Koz
Old 10-01-13, 08:12 PM
  #92
T4Fun
T4Fun's Avatar
any idiot lights come on the dash with these larger tires on the gx?
they shouldve put LX sized rims on this
Old 10-02-13, 08:21 AM
  #93
Koz
Koz's Avatar
What are you referring to?
Koz
Old 10-02-13, 01:29 PM
  #94
Eppieguy
Eppieguy's Avatar
Koz
I believe what he is asking is when you change to a larger size tire does the GX throw any codes in which would turn on an idiot light.
Old 10-03-13, 04:10 AM
  #95
Koz
Koz's Avatar
No idiot light, 10K miles and everything is fine. Actually, even if someday I do not need LTs and need to replace the tires, I will put these same tires back on. The overall ride (towing/non-towing, off-road and highway) is excellent!
Koz
Old 10-05-13, 12:46 AM
  #96
T4Fun
T4Fun's Avatar
i would love to put wider tires, but our rims only 7.5 inches wide and 265 is max tire size width safely can be put on. anything higher, risk of tire blow out goes up. not a chance to take when driving at 80 mph, and the heat buildup causes tire expansion, further increasing risk.
Old 10-16-13, 02:10 AM
  #97
T4Fun
T4Fun's Avatar
Costco was sued by someone who had an accident and claimed it was caused by not installing the OEM size, and won. This is why the big corp have this policy.
Koz
now if your insurance company finds this out, that u put wrong tire size and have accident, will they pay out? if they have good lawyers, likely not.
Old 10-18-13, 07:08 AM
  #98
Koz
Koz's Avatar
The bigger LTs I put on are wider than the OEM size and they are perfectly safe to use with the OEM 7.5" rims. Both sizes (OEM and 275/65/18 LTs) have the same minimum rim size rating. Also, being they are LTs they can carry more weight safely which makes them less stressed at normal weights.
Koz
Old 10-18-13, 12:15 PM
  #99
T4Fun
T4Fun's Avatar
Koz
Didn't known that. Ive read otherwiseb on 4R.ORG
Old 02-17-14, 11:11 AM
  #100
jaleels
jaleels's Avatar
I finished up the brake job. I replaced the semi-metallic pads with ceramics and painted the calipers. The brakes stop and feel much better.
Koz
I really like your tire and brake changes. Thanks for you posts; they have been very helpful.
Old 02-19-14, 10:57 AM
  #101
Eppieguy
Eppieguy's Avatar
I just ordered the LTX MS2's 275-65-18 from Costco and they asked what they were going on and told me it was a bigger tire than OEM, I told them I knew and I knew they would fit and then there was no futher questions asked. They will be in tomorrow so I guess I'll have them put on tomorrow afternoon.
Old 02-19-14, 01:34 PM
  #102
frank69m
frank69m's Avatar
Odd because Costco is usually picky about putting the same size OEM tires. I guess the MS2's didn't have 265's?
Since it seldomly rains here in California and I like a better handling tire, I may just go for the Latitude Tour HPs
Old 02-19-14, 03:33 PM
  #103
Eppieguy
Eppieguy's Avatar
They have the OEM size in the MS2's. According to Costco's website it's up the the store tire manager as to what they will install on a vehicle.
Old 03-09-14, 08:24 PM
  #104
11GX460
11GX460's Avatar
Hi Koz,
I am a new member and in the process of purchasing new rotors for my truck. I came across your photos and would like some more info. Could you please let me know how your rotors and brake pads are holding up? Approx how many miles do you have on them? And, in your opinion, are they better than the OEMs? Any help would be appreciated. BTW, the after reading about everyone's Michelin LTX M/S2 experience, they will be my next set of tires. Thank you.
PS: Has anyone on this board tried Brembo or EBC rotors on their GX460? And if so, how do you like them?
Old 03-10-14, 05:54 PM
  #105
KVA
KVA's Avatar
I have StopTech rotors and pads on all four corners of my T4R and they work great - basically the exact same brake setup as the GX. That said, unless you need to replace the OEM rotors and pads, they are normally very good.
I had specific issues that couldn't be fixed so I opted to try the switch and all is good! If I had to do it again I would probably go with EBC yellow pads as I have heard good things.
Quick Reply: LT Tires on GX460
