LT Tires on GX460
Old 03-17-15, 04:42 PM
  #136
JohnJerk
JohnJerk's Avatar
Originally Posted by tecman
The suspension would compensate for the smaller tire and I think the GX tranny is capable of handling the imbalance.
I plan on having the smallest tire available put on my spare wheel to fit inside my duel exhaust set up (I just can't seem to get around to it ).
The spare tire is obviously temporary so what is the problem with this type of set up?
You need the spare to be close in size to the other three tires else the traction control will go wild and I believe the differentials will be working harder too as tires spin at different speeds. Messing with tire inflation should get you to the dealer anyway and is my plan if/when my 275 Duratracs get a flat.
Old 03-18-15, 06:19 AM
  #137
Eppieguy
Eppieguy's Avatar
Originally Posted by jaleels
The ltx tires raises the center of gravity higher on th gx. The vehicle does not need to be any higher. The higher center of gravity does not inspire confidence on the road. The ride on the tires is not that different from the original tires. I should have kept the original spare tire, there was nothing wrong with it. The tires are ok and handle curbs and off roading very well, but the rubbing is annoying.
When I changed my brakes I noticed rubbing on the interior of the wheel well. No one else has mentioned this but it happens.
I disagree with the rubbing issue, I have been running the oversized LTX's for 15k and I've had zero rubbing. I had to remove one bolt from the inner fender well in the front and I have not heard or seen any rubbing at all. Maybe since you have the Air Suspension and I have the base that may be the difference but I would not hesitate on buying these tires again. I have flexed it pretty good on the beach as well with no issues.
Old 03-18-15, 06:25 AM
  #138
Eppieguy
Eppieguy's Avatar
What about all of the AWD vehicles that come with a donut spare? I am not concerned about running a smaller spare to get where I'm going in case of a flat tire. I would not intend on running the spare for any length of time as my spare rim is not the same as my other wheels so it would only be used in an emergency.
Old 03-20-15, 07:28 AM
  #139
JohnJerk
JohnJerk's Avatar
Donuts have the same outside diameter as the stock tires, they are just skinny.
Old 03-20-15, 09:51 AM
  #140
T4Fun
T4Fun's Avatar
most awd vehicles come with same size tire, donut or no dunut, they are same diameter
what vehicle with awd comes with a donut spare of different size?
and in fact running different tires sizes on awd/4wd will screw up tranny
running 275s on these skinny 7.5 inch rims is unsafe. You need atleast 8 inch wide rims for them to fit properly, otherwise, you risk blowout, early tire failure, suspsension issues, and list goes on
Old 03-23-15, 06:10 AM
  #141
JohnJerk
JohnJerk's Avatar
What!? 7.5 is in spec for common 275 ATs. Some are a go at 7.
Old 03-23-15, 11:52 AM
  #142
T4Fun
T4Fun's Avatar
http://www.yokohamatire.com/tires_10...m_wheel_width/
http://www.etmags.com/pdf_download_d...chart_2010.pdf - check out last page for 18 inch tires
some manufacterers state even rim width should be 8.5-9 inches minumum
point is you CAN do it, whether its safe its your issue
Old 03-23-15, 11:17 PM
  #143
JohnJerk
JohnJerk's Avatar
Those are 26" tires, so not even remotely applicable to a GX. Even yokohamas geolander in 275 65 18 is ok with 7.5 rim. Your not helping the board advance its knowledge with these posts.
Old 03-24-15, 12:50 PM
  #144
JDSTL
JDSTL's Avatar
No problem running a 275 on a 7.5" wheel.
http://m.michelinman.com/tire-selector/tire-download-techspec-pdf.page?
My link doesn't work but it's straight from the Michelin site.
Old 03-27-15, 04:20 PM
  #145
hrod79
hrod79's Avatar
2 issues,
1. I can't believe that the 1/2" to 1" you gain by increasing tire size would make you feel the truck is any different as far as top heavy or even remotely change the center of gravity. (what a stretch)
2. an LT rated tire will have a stiffer sidewall which in fact will reduce body roll compared to a P rated tire that comes on the truck.
For those of you who are unfamiliar with this truck, this is a 150 Series Land Cruiser and is an extremely capable vehicle on and off the road. You bought a luxurious truck with roots in over landing and 4wheel drive.
Old 03-28-15, 06:44 AM
  #146
jaleels
jaleels's Avatar
To begin with you had three issues not two issues. This message board is not a place to criticize anyone's opinion. You don't have the tires on your vehicle so you cannot make any statements about how the vehicle feels.
Old 03-28-15, 10:31 AM
  #147
Eppieguy
Eppieguy's Avatar
I can, and it feels a lot more stable at highway speeds, stiffer sidewalls make it handle a lot better and I have zero rubbing issues. I agree with what others have posted, all positive about changing the tires to the larger size LTX. I have put over 10k on them and I'm very pleased with the upgrade over stock.
Old 03-30-15, 09:12 AM
  #148
Jacket
Jacket's Avatar
This is one of the reasons why cars come with the switch to turn off the VSC and TRAC. If you have to run a smaller tire for a short distance to get you home, then disable the electronic traction controls for that time period if the systems try to overcompensate.
Old 05-07-15, 01:35 PM
  #149
hrod79
hrod79's Avatar
@jaleels I apologize for the previous post felt like an attack and it was 2 issues and a comment.
I don't have the Michelin tires on my GX but have had several LT sets on other vehicles and all LT tires give you the same results as I stated. From looking at your pictures you are having rubbing. That is clear. But your problem is not the tires. It is in the suspension itself. I don't have an air ride suspension in the rear as you do and with my larger LT tires I have about2.5" to 3" from tire to frame. Your axle is floating which will result in exactly the feeling that you are experiencing. I don't know if it is a result of the air ride vs standard suspension but your axle is clearly shifting left to right 2-3" which is bad. I suggest you get that looked at by the dealer or mechanic.
Old 06-22-17, 11:25 AM
  #150
7h3Stig
7h3Stig's Avatar
I realize this is an old thread, but I am curious if anyone here can definitively confirm that a 275/65/18 will fit with no rub on stock suspension. I have a 2015 Premier with the F-Sport 18x7.5 wheels. Any intel would be greatly appreciated. I am considering the Defender LTX M/S as a top contender right now. Thanks.
Quick Reply: LT Tires on GX460
