Turn Signal Wiring Diagram
Old 04-15-12, 10:05 AM
Capirato
Capirato's Avatar
Originally Posted by Jeff Lange
Unfortunately the turn signals are not wired that way. They are positively switched on the bulb side (flashing).
There are negatively-switched elements to the switch itself, but left and right are separate, so you'd need to consolidate them using diodes, or similar. Do you need a flashing input or a solid input?
Jeff
Jeff.....
I need a solid negative input, whenever the right or left turn signals are flashing.
~ Cap
Capirato is offline
Old 04-16-12, 04:06 AM
Koz
Koz's Avatar
Sounds like you would need a control relay with a timer that will de-energize after no power is detected for a couple seconds.
Koz
Koz is offline
Old 04-16-12, 11:31 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
You just need a couple of diodes to do it, just tap in to the two wires at the turn signal switch and if either one goes to ground you'll have your ground.
Jeff
Jeff Lange is offline
Old 04-16-12, 12:13 PM
Capirato
Capirato's Avatar
You just need a couple of diodes to do it, just tap into the two wires at the turn signal switch and if either one goes to ground you'll have your ground.
Jeff
Jeff.....
That should do it. Now I need to buy two diodes and a relay. The relay to provide a ground for the input of the module I am using.
Thanks for your continued support !!!
~ Cap
Capirato is offline
chinox22x
06-03-19 06:31 PM
Enz
RX - 1st Gen (1999-2003)
16
10-13-12 10:35 AM
Capirato
Maintenance
04-15-12 03:25 PM
ISCjonny
02-01-08 10:14 PM
rodel
05-25-07 12:15 AM
Quick Reply: Turn Signal Wiring Diagram
