Couple of questions..
Old 07-04-11, 04:58 AM
genedwes
genedwes's Avatar
Default Couple of questions..
New to the forum. Currently drive 2008 X5. Thinking about going to the GX!
What changes if any on the 2012 are rumored. Can't find any news when searching!
Have seen on this forum some owners say they do not like the transmission downshifting on a grade when driving on the interstate. Hope I have listed this right as it is from memory. I have had vehicles in the past do this and I don't find this as a plus. I am not talking about driving in the mountains, just normal driving.
Thanks for your help.
genedwes is offline
Old 07-04-11, 07:56 AM
Craig B
Craig B's Avatar
Hi Gene, I got rid of my 2009 X5 twin turbo diesel for the GX 460 premium. I haven't heard about the changes for 2012. They had minor changes for 2011. My GX 460 does downshift when going up hills when the cruise control is on. My X5 didn't do that, but was the biggest POS I think I've ever owned. It was in the shop over ten times in one year. My GX has been pretty much trouble free.
Good luck with your decision...
Craig B is offline
Old 07-04-11, 08:44 AM
Luke27617
Luke27617's Avatar
Make sure you check if you feel vibrations in steering wheel at highway speeds (65+ MPH). I am no longer the GX owner becuase of that. The rest of the vehicle was great.
Luke27617 is offline
Old 07-04-11, 10:47 AM
deusex
deusex's Avatar
I have a 2011 Premium (about 8 months now) and so far zero problems (well, besides little rust developing under the vehicle) Just drove it from NY to PA and back and it was a great drive.
deusex is offline
Old 07-04-11, 12:24 PM
rockydog
rockydog's Avatar
I traded my 2007 X5 for a GX 460 Premium. No problems so far. My X5 had problems from the day it was delivered.
rockydog is offline
Old 07-04-11, 12:46 PM
SaniDel
SaniDel's Avatar
<SNIP>
<SNIP>
You are correct about the GX 460 downshifting and we have discussed this at:
https://www.clublexus.com/forums/gx-...ownshifts.html
Bottom line ... the GX 460 can be left in 'Drive' and it will "shift for itself" but you can also force downshifts by tapping the brake pedal ... if conditions are right. In general, that means your foot is off the gas, the vehicle speed is high enough and the vehicle is accelerating, i.e., it is on a downhill run. Presumably, on a steep enough and long enough downhill you can force sequential downshifts, but the most we have gotten is two ... there aren't any good hills in Delaware!
My wife prefers 'Drive' but I prefer 'Sport'. I prefer to force downshifts by pulling back on the shift lever rather than tapping the brake. Also, pulling back on the shift lever always forces a downshift ... unless the engine would exceed redline. There's a practical limit in convenience, smoothness and noise, not to mention wear and tear on the drive train ... at some point it is better and safer to use the brakes!
Needless to say, as any automatic transmission vehicle, downshifts also occur when required due to acceleration, going up hills, etc. However, the GX 460 tries very hard to get into the highest gear, which is how it achieves such impressive highway mileage:
https://www.clublexus.com/forums/gx-...y-mileage.html
Although we haven't driven any further west than Michigan and certainly not on the mountainous Interstates of the West, I suspect one could readily drive the GX 460 on any Interstate in 'Drive' although with heavy use of the brakes. It is on secondary roads that are steeper and curvier than the Interstates that driving becomes a problem, but that's where the 'Sport' mode is useful.
Regards,
SaniDel
SaniDel is offline
rsherrard
LX - 3rd Gen (2008-2021)
05-09-14 01:23 PM
JDG
GX - 2nd Gen (2010-2023)
12-27-12 04:04 PM
Myke215
GX - 1st Gen (2004-2009)
11-14-12 08:30 AM
biggiefat
16
09-16-12 07:57 AM
frank69m
12
04-22-11 07:22 AM
Quick Reply: Couple of questions..
