Manual Fuel Door switch
Does anyone know where the manual switch for the fuel door is located? I searched the rear compartment area that the manual said the the switch is located at and I could not find it.
Attachment 178097
If anyone knows where the switch is located at please post a picture.
Attachment 178097
Thanks Luke, I was able to push my hand back behind the body work and after a couple of minutes I felt a lever and pulled on it. I also followed a wire that led to the switch for the fuel door. The manual is not clear on some of the features and the pictures are very misleading. There might be a language issue and an assumption that designers know where everything should be.
Here is the door to the jack compartment.
Behind this area is where you can find the lever
This is a shot of the lever that is concealed. You will never see this lever unless you take a picture of it with a small camera. You will always need feel behind the bodywork and pull on the lever.
. 18 LX 570 3row ????
How about the filler being on the passenger side. 2018 LX570 3 row. ?.???
Attachment 178097
Attachment 178097
Super Moderator
Posts above are for a 460
Attachment 178123
Attachment 178124
Attachment 178125
Attachment 178123
Attachment 178124
Attachment 178125
Please let me know if you have solved the issue.
Thanks
Super Moderator
Here is FSM content related to the fuel door.
GX46O (11-09-20)
Acrad (11-09-20)
alexus
09-17-02 02:32 PM
