Power outlet 120 V AC (Type B)
Old 04-30-10, 07:20 AM
jaleels
jaleels's Avatar
Default Power outlet 120 V AC (Type B)
I saw a reference to a Type B power outlet in the GX 460 owners manual. Does anyone know if this is a option for U.S. cars?
outlet 3.doc
jaleels is offline
Old 04-30-10, 07:50 AM
antonio98
antonio98's Avatar
The 120V two prong outlet is standard.
antonio98 is offline
Old 04-30-10, 08:28 AM
SaniDel
SaniDel's Avatar
Our GX has the outlet, but not the switch so presumably we do not have 120 VAC service.
SaniDel is offline
Old 04-30-10, 10:51 AM
antonio98
antonio98's Avatar
They must have decided to forego the switch after the documentation was created.
The outlet works automatically once your car is in the IGNITION ON mode.
Old 04-30-10, 12:37 PM
jaleels
jaleels's Avatar
Here is a picture of what was in the manual. There is a Type A and a Type B.
jaleels is offline
Old 04-30-10, 01:12 PM
SaniDel
SaniDel's Avatar
Type A does not mention the switch, but emphasizes the limit of 100 Watts. A picture of Type A can be seen on page 537 of the Owners Manual. It seems the difference between Type A and Type B is the power rating. Type B is rated at 400 Watts and includes the switch on the dashboard.
https://secure.drivers.lexus.com/lex...html&locale=en
SaniDel is offline
Old 04-30-10, 06:04 PM
antonio98
antonio98's Avatar
It appears that this Type B switch is offered on the Ultra Premium in Canada.
Can anyone from Canada confirm this?
Old 07-05-10, 07:19 AM
Capirato
Capirato's Avatar
Default 120 Volt Outlet
Has anybody installed a 120 Volt outlet in the front compartment ??
Sure would be handy to have.
~ Cap
Capirato is offline
Old 07-05-10, 08:03 AM
Luke27617
Luke27617's Avatar
~ Cap
I have just bought a $10 converter so I can connect my laptop at front. It is not as pretty as factory plug on the back, but works perfectly when need one.
Luke27617 is offline
Old 07-05-10, 05:25 PM
Capirato
Capirato's Avatar
Luke.....
Also, one could use an extension cord.
When I get around to it, I'm going to make the 12 Volt power source, constantly hot.
At the same time, I'll put a 120 Volt outlet some place out of the way and out of sight, but handy.
~ Cap
Capirato is offline
Old 06-02-11, 07:47 AM
russcarver
russcarver's Avatar
Capirato,
Did you ever get the 12v power source constantly hot? If so, can you describe how to do it for me? Does it also make the USB power source constantly hot?
Thanks!
--Russ
russcarver is offline
Old 06-04-11, 09:00 PM
superstar3
superstar3's Avatar
I have it in my GX 2010 Ultra Premium. It is basically a switch to engage if the power supply requirement for the plugged in item is over 100w.
superstar3 is offline
jaleels
GX - 2nd Gen (2010-2023)
11-09-20 06:21 PM
madspin
HS 250h Model (2010-2012)
03-13-18 08:01 PM
RAMBLER2
01-13-18 10:05 AM
Karimay23
05-02-15 12:54 PM
iRyan
05-13-14 01:11 AM
Quick Reply: Power outlet 120 V AC (Type B)
