Go Back   Club Lexus Forums > Lexus Model Forums > GX Models > GX - Second Generation
Sign in using an external account
Register Forgot Password?
Official 2nd Gen GX Modification (DIY) Thread!!
Thread Tools Search this Thread Display Modes
Old 03-24-10, 06:46 PM   #31
ybing
Trader Score: (0)
Thanks guys, I still have to wait for next week until they restock, just wondering, the rear two dome light also have two bulbs in it right?
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
'14 IS350 Ultra White/Rioja Red (Nov 15, 2013 - )
'13 IS250 Nebula Gray/Saddle & Black (Apr 08, 2013 - Nov 15, 2013)
'10 GX460 Starfire Pearl/Black (Mar 12, 2010 - Apr 08, 2013)
'06 IS350 Blue Onyx/Cashmere (Feb 28, 2006 - Feb 28, 2010)
ybing is offline   Reply With Quote
Old 03-24-10, 06:55 PM   #32
Luke27617
Trader Score: (2)
Luke27617's Avatar
Quote:
Yes, two as well
Luke27617 is offline   Reply With Quote
Old 03-25-10, 10:21 PM   #33
antonio98
Trader Score: (0)
Here are a couple of photos showing the map lights with LED vs. standard and the door light with illuminated door sill.
Official 2nd Gen GX Modification (DIY) Thread!!-gx-lights-011.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-gx-lights-013.jpg
antonio98 is offline   Reply With Quote
Old 03-25-10, 10:32 PM   #34
Luke27617
Trader Score: (2)
Luke27617's Avatar
Quote:
Looks good!!!! I need to do the doors too. Working on HID and hopefully will post some pictures tomorrow with DIY. There are couple difficult points I didn't expect which added couple hours to the project. Will try to finish tomorrow after work.
Old 03-25-10, 11:11 PM   #35
antonio98
Trader Score: (0)
All the LED's are in now.
Thanks for your help Luke!
Old 03-26-10, 06:30 AM   #36
Luke27617
Trader Score: (2)
Luke27617's Avatar
HIDs next?
Old 03-26-10, 09:24 AM   #37
antonio98
Trader Score: (0)
Quote:
Originally Posted by Luke27617 View Post
HIDs next?
I have the Premium, so it came with HID's.
The LED parking light bulbs match much better than the old filament bulbs.
Old 03-26-10, 09:32 AM   #38
Luke27617
Trader Score: (2)
Luke27617's Avatar
So you are one of the lucky one living the Premium privlage life
Old 03-26-10, 10:06 AM   #39
XenonDepot
ClubLexus HID Kit Sponsor
Trader Score: (9)
XenonDepot's Avatar
KBcarstuff XenonDepot
Quote:
Originally Posted by luke27617 View Post
so you are one of the lucky one living the premium privlage life
lololol
__________________
ClubLexus SUPER SALE is on now!! - SAVE $$$
AUTHORIZED LEXUS Parts & Accessories VENDOR SINCE 2004 - SHOP WITH CONFIDENCE
XenonDepot is online now   Reply With Quote
Old 03-26-10, 11:20 PM   #40
Luke27617
Trader Score: (2)
Luke27617's Avatar
Default HID Kit install
First of all, I would like to thank Steve from XenonDepot for all help. He provides top notch customer service and very high quality kits. Fully recommend buying HID kits from www.XenonDepot.com aka www.KBcarstuff.com
So lets start with DIY instructions.
I have decided to go with Xtreme Digital 4300k Philips HID kit. I want the most factory look and Philips brand name. For anyone who has Base GX460 and want to upgrade to HID, I would recommend to go with this kit. If you want to skip one of the steps of routing additional cable through dust cover then I would go with non-Philips kit which already has the calbe routed through grommet. Will cover that shortly. When comes to color temperature, I wouldn't go above the 5000k kit as I don't like the blue tint you see all teenager driving with. I like the factory look.
Overall everything is plug and play and process takes +/-20 minutes for pluging the kit and making it work. It took me substantially longer as I couldn't find a good mounting location and as well I had to deal with dust covers.
Step 1.
Plug the kit to make sure you have a working one. There is always a small chance to have a defective kit and it is painful to find out this after you mount nicely everything and have to start over. Also be careful with the factory plug which factory bulb was plugged in. It is very fragile. I broke off the clip which holds it plugged in and had to use electric tape. First picture shows the plug.
Step 2.
Remove dust covers and drill 18mm hole in the middle. If you go with the Philips kit, you need to perform one more step (it will eliminate in near future per Steve). Notice that I have drilled an additional tooth. Factory plug for the light bulb is inside the headlight so I had to make space for a cable from the harness to plug in to the plug. If you go with non-Philips kit, you will not have to as the wire is already integrated into water-tight grommet. Since I had to improvise, you will see the brown glue to make the hole water tight. This will not be necessary if you go with non-Philips kit.
You will notice on below picture that I took apart plug which needs to be mounted inside the headlight. It is necessary as the hole in the dust cover will be too small to pass it through it. Plug has clips and it is very easy to remove/plug in wires. Again this is for the Philips kit.
Official 2nd Gen GX Modification (DIY) Thread!!-img_3400.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3402.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3409.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3410.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3414.jpg
Old 03-26-10, 11:22 PM   #41
Luke27617
Trader Score: (2)
Luke27617's Avatar
Step 3
Here are mounting locations of all components on the passenger and driver side. I have used included double sided tape (have cut in smaller pieces for contact areas) and as well zip ties. The ballast on driver side is only supported by double sided tape on edges (a big hole under) and no place to run zip ties for extra support. Since it lies flat, I hope it will work.
Official 2nd Gen GX Modification (DIY) Thread!!-img_3419.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3420.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3421.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3422.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3423.jpg
Old 03-26-10, 11:24 PM   #42
Luke27617
Trader Score: (2)
Luke27617's Avatar
Pictures continue
Official 2nd Gen GX Modification (DIY) Thread!!-img_3425.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3426.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3427.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3428.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3431.jpg
Old 03-26-10, 11:34 PM   #43
Luke27617
Trader Score: (2)
Luke27617's Avatar
Pictures continue
Old 03-26-10, 11:35 PM   #44
Luke27617
Trader Score: (2)
Luke27617's Avatar
Lights in action... In order you see:
- 4300k Philips HID vs. LED 5k side marker. It seems to be a big difference, but it takes around 100 hours for Philips bulbs to break in and they should be of 4700K temperature. If you want crisp light from beginning, I would recommend going with the 5000k HID (no blue tint).
- Street shot - headlights are not blue (camera issue), but it gives you an idea of brightness difference between headlights and fogs which from factory use the same H11 bulb
- Driving (at least 2-3x brighter than stock bulb)
- Just headlights on
- Headlights and fogs on
Official 2nd Gen GX Modification (DIY) Thread!!-img_3436.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3437.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3444.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3448.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_3449.jpg
Old 03-27-10, 01:47 AM   #45
ybing
Trader Score: (0)
Those after market HID are always better than stock one, but it just need a lot of work to install it, I installed on my IS, but one of the bulb burn after 1 year use
__________________
Similar Threads
Thread Thread Starter Forum Replies Last Post
<<< HID Powerhouse <<< **2008-2013 IS-F H.I.D. and L.E.D. Lighting Upgrades** HIDPH Club Lexus Vendor Marketplace 277 Today 02:02 AM
DIY Door LED Guide AL13NV8D3R GS - Fourth Generation 10 11-11-14 03:24 PM
LED Upgrade Guide JiniJazz RX - Third Generation 26 10-08-12 04:05 PM
3GS Frequently Asked Questions and DIY Thread - Please look here first! passnu2 GS - Third Generation 0 03-05-10 05:44 PM
3GS FAQ (Frequently Asked Questions) and DIY Thread ★★ New Members Start Here! ★★ FAQ & DIY GS - Third Generation 0 04-13-01 05:00 AM
Tags
460, 5k, 6k, diys, dome, dyi, gx, gx460, gx470, interior, led, lexus, lights, modifications, putco, vleds
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
