LED Turn Signals
LED Turn Signals
I am ready to convert my turn signals to LEDs, but I have noticed that the electronic flasher is much bigger and uses a different plug than previously I have seen on my gs350.
Anyone know where to get an aftermarket one to correct the hyper flashing when changing to LED bulbs for turn signals?
Flasher
Does anybody know if I can get a louder flasher to replace the stock one ??
I can't hear the darn thing and it is embarrassing to realize the turn signal has been on for miles.
~ Cap
~ Cap
tk8lm6 (09-21-21)
Is it an easy plug and play if they come out with an aftermarket model that handles LEDs?
It is very easy to find. Turn the turn signal on and listen to the clicking noise. When you touch the right component you will feel the clicking too. Like in most cars, it should be accessable from under neat the steering wheel. There is a pannel above pedals which is held by couple screws. Take it off and let the hunt begin.
LED 7440A turn signal bulbs
Just upgraded my front & rear turn signal lights with LED bulbs. The LEDs are hyper-blinking due to requiring resistors. I am hesitant to install them bc the hyper-blinking is cool & distinctive. The LEDs make the lens clearer without the visible amber color and are super bright. Just want to double check if the hyper-blinking mode is against the law or traffic & law enforcement provisions???
Traffic provisions vary by state but there's the possibility of a bored cop pulling you over. If they see the hyper blinking from one angle, they are going to assume one of the corresponding indicators is out, which they can then use to either write you a ticket, or as a reason to pull you over to check for other things (such as whether you're intoxicated when driving late at night).
That may be unlikely, so it probably isn't worth worrying about, but a fast blinking indicator means a dead bulb and so it doesn't really say "cool" and "distinctive" as much as it says "something is wrong with my car".
I could see this being an excuse to pull you over, especially at night. Possible example from police: "sir, do you know you could cause a seizure of another driver with your strobe lights"?
I advise Against this. You are asking for trouble. The same can be said for tinted license plate covers. I know of people that have been pulled over for this.
I agree with the others. Every time I see a kid with a hyper flashing LED bulb, I think either he did not know how to fix it or thinks he's cool. Personally, I think it is annoying to see; plus, the hyper clicking sound it makes in the interior is really irritating, but that's just me.
The fast blinker is not against the law. A blinker that doesn't work is...which is what many times a fast blinker indicates. This gives an officer probable cause to pull you over. For fast blinkers to be illegal, not only does the law have to indicate how fast a blinder should blink, but the enforcing officer should be able to measure the rate in which a blinker blinks.
Okay
All of you have a valid perspective.
Have anyone changed out their bulbs to LEDs bc my next question is how many resistors do I need for the LEDs to blink normally - 1 to 4?
Depending on the LED bulb you choose, some bulbs claim to have the resistors built in. I went with VLEDs, which are pricey, but very nice. It required 4 resistors, and I had to modify the rear 2 to make it work.
On Honda vehicles some people claim you don't need a resistor unless you replace both front and rear when using these bulbs:
But the only way to make sure is to replace and try.
Hyper flash, in my opinion, looks unprofessional...
