DVD Override and Pictures! - Page 5 - Club Lexus Forums
Go Back   Club Lexus Forums > Lexus Model Forums > GX Models > GX - First Generation
Sign in using an external account
Register Forgot Password?
P
Thread Tools Search this Thread Display Modes
Old 06-30-04, 06:09 PM   #61
davepl
Garage is empty, add now
Trader Score: (0)
Default Adding a backup cam...
I'd like to be able to adapt this mod to my project of adding an aftermarket backup camera; the only missing piece would be to force it to display the video input you supply.
Obviously each time you backed up you wouldn't want to have to go through the menus in the back seat to tell it to display video... does anyone have an inkling whether given a composite video source there's a way to make the front screen display it?
I wonder if by some fluke pumping it into the video input in the rear console will magically work, but I'm guessing without asking the rear seat entertainment to play it, it won't.
- Dave
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
davepl is offline   Reply With Quote
Old 06-30-04, 08:24 PM   #62
Capirato
Trader Score: (0)
Send a message via AIM to Capirato
Default Re: Adding a backup cam...
Quote:
- Dave
Dave.....
Nav-Tv makes a module to pump TV into the NAV. I would think that they make a module to pump video from a Camera.
www.nav-tv.com
~ Cap
Capirato is offline   Reply With Quote
Old 07-07-04, 07:17 PM   #63
Galanty
Trader Score: (0)
I have gone to two radio shacks, and they don't seem to have this switch.
1) Does anyone have a part number for the switch?
2) How long should the wire be?
3) What colors and what size wire is recommended?
Everyone who help make this post possible is my hero!
Galanty is offline   Reply With Quote
Old 07-07-04, 08:48 PM   #64
mogulbumm
Trader Score: (0)
1) Don't know part number, but any low voltage double-pole double-throw switch should work. Note: if just for the DVD override and not for the screen, you don't really even need the switch... I'm just anal and like to put things back at default when necessary. Plus, it makes for a really quick switch from the DVD to the NAV screen when my passenger has a DVD playing and I need to switch back to NAV for a quick peek
2) You can get a spool of 4-wire cable for a few bucks at radio shack, so the length shouldn't be much of an issue. I think it was only about 18" or so from the back of the screen to the switch. You may need a few feet to wire up the NAV. I've been too busy to do this mod yet...
3) Colors are optional, especially since they are hidden. Light gauge is fine (12-18 or so should be MORE than adequate). It carries virtually no current.
Good luck.
__________________
2003 Lexus GX470 - Silver Pine/Charcoal - Loaded
2002 Harley Davidson Road King with Screaming Eagle Stage I & II and Chameleon Flamed Paint
1999 Black Lab
2000 Yellow Lab/Pit Bull Mix
2003 Beautiful Baby Girl
mogulbumm is offline   Reply With Quote
Old 07-07-04, 10:41 PM   #65
Gohawks63
Trader Score: (0)
Default Re: Re: Adding a backup cam...
Quote:
Originally posted by Capirato
Dave.....
www.nav-tv.com
~ Cap
If you can get wiring schematics of the '04 LX/Land Cruisers, you may get your answer. Backup camera comes with the Nav. When you put the car in reverse, it oautomatically overrides the Nav screens.
__________________
2004 Toyota Land Cruiser w/Navigation
2006 Acura RL
Gohawks63 is offline   Reply With Quote
Old 07-07-04, 11:34 PM   #66
Galanty
Trader Score: (0)
mogulbumm:
You are my hero ... and thanks you for your quick response.
I agree with you on using the switch ...
I went to another Radio Shack, and they had a similar switch to your picture, but it was not the same size as the entire existing black insert on the dash.
Did you drill a hole in the existing black insert to insert the radio shack switch, or was your version the exact same size as the black insert next to the shown next to "2nd strt". It almost looks like your square version has a smaller rectangler plug insert with in the square insert.
Also did you choose the square insert location next to "2nd strt", instead of the smaller rectangle insert a little lower on the dash for any important reason?
Radio shack switches link below: Part 275-692 and 275-694
http://www.radioshack.com/iphraseget...Aoid&text=&sf=
Old 07-08-04, 09:54 PM   #67
mogulbumm
Trader Score: (0)
I used the 275-694 switch and drilled a hole in the blank. It was just easier, plus I knew I could get another blank if I screwed it up (probably for about $75 at Lexus ) It is just a round hole just slightly larger than 1/2" if I remember correctly. If you drill it exact, the nut on the switch will hold it in perfectly.
Didn't look at any other mounting spots since that one was ripe for the picking.
__________________
1999 Black Lab
Old 07-16-04, 08:59 PM   #68
Galanty
Trader Score: (0)
Default DVD Override and Pictures
Mogulbumm:
I must be the technically retarded you were referring to.
Could you do a schematic on the switch based on your pictures/colors?
Screen Ground Switch Col. A Switch Col. B Car
Thanks ...
Old 07-16-04, 11:39 PM   #69
lexusondubs
dubsonlexus
Trader Score: (8)
lexusondubs's Avatar
Send a message via AIM to lexusondubs Send a message via MSN to lexusondubs Send a message via Yahoo to lexusondubs
i love your list ........
Tools you will need:
1. Wire cutters/Wire Stripper
2. Pry tool (I used a small putty knife)
3. Drill (if you are installing the switch)
4. Beer
5. Socket Wrench
6. Twist Connectors, Electrical Tape, or Solder/Soldering iron if you feel fancy
7. Beer
8. Light gauge wire
but I have learned ONLY to have a beer when the job is COMPLETE !!!!! or else there could be mistakes !!!!
__________________
WWW.JINSOKU.COM
lexusondubs is offline   Reply With Quote
Old 07-29-04, 10:35 AM   #70
gordo251
Trader Score: (0)
Question Must you have teh factory rear entertainment
I just purchased a 2004 Gx470 Yesterday and I love It! I was wondering if it is possible to perform this mod if you do not have the rear entertainment system installed? If so, where would the dvd's play from? I have teh Navigation but not the dvd entertainment system. Thanks
gordo251 is offline   Reply With Quote
Old 08-08-04, 02:09 PM   #71
LexLuder
Trader Score: (0)
LexLuder's Avatar
Default mogulbumm
Thanks for all the tips and tricks, now watching movies
__________________
http://www.clublexus.com/gallery/dat...pg05-thumb.png
GX470- Built 4/18/04 w/ KDSS
2003 F150 4x4 Lariat
2002 BMW 540
2002 Harley Davidson VRSC
2001 252 Mako
LexLuder is offline   Reply With Quote
Old 08-09-04, 09:44 PM   #72
mogulbumm
Trader Score: (0)
Default PLEASE DO NOT WATCH DVDS WHILE DRIVING
Fellow Lexus Folk,
PLEASE do not do this mod to watch DVDs while driving. I did the mod solely so my passenger (wife) can work the DVD player for said other passenger (14 month old).
In 38 states, it is illegal to have a DVD player in view of the driver. Just recently, there is a case in which a driver crashed while watching a DVD. Passengers in the car were killed and the driver is now on trial for MURDER!
It is not worth it! Please respect the rules of the road and use the mod safely for its intended purpose.
Thank you and good luck!
__________________
1999 Black Lab
Old 08-09-04, 11:23 PM   #73
LexLuder
Trader Score: (0)
LexLuder's Avatar
Default mogulbumm
I do thank you for your advice and concern, I did this option just for my wife and while driving with kids, I hardly even listing to radio, while at the road I am a defencive driver so I am like the camaleon with my eyes looking for any danger sign.
__________________
2002 BMW 540
2001 252 Mako
Old 12-21-04, 06:00 PM   #74
Triniellis
Trader Score: (0)
Default Es 330
Will this mod Work on a ES 330?
Is the Nav Mod cables under the passenger seat or behind the nav screen?
Having a video play up front will cause any driver to eventually watch so becareful.
I would like the Nav to work when a passenger is in the passenger seat . Lexus can tell when a passenger in sitting because the air bag is enabled so they should also enable the nav so that the passenger could make the ajustments and disable it when there is no passenger.
So any help will be appreciated.
TRINIELLIS
Triniellis is offline   Reply With Quote
Old 12-22-04, 08:38 PM   #75
Fusion400
Trader Score: (0)
Send a message via ICQ to Fusion400 Send a message via AIM to Fusion400
Default Switch Wires???
OK now that I have some free time on my hands I going to do the dvd override mod. I am a little confused may be you guys can help me out. Based on the the previous posts and some pictures by "mogulbumm" this is what i got. Please see the illustrations below:
My questions are: what is next? do i connect all three wires solder together (green-from the car, red, and black) to the ON switch and the OFF switch solder together the green wire (coming from the dvd screen)plus a ground wire (5th wire)?
Thanks
FUSION
__________________
'04 GX470 | Blue Mica w/ 6000K HID
'99 GS400 | Silver
Fusion400 is offline   Reply With Quote
P
Tags
2006, copyright, cutting, dvd, gx470, lexus, mod, moving, navigation, overide, override, phone, pictures, rear, screenoverride, wires
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Contact Us - Club Lexus Home - Archive - Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Service | JOBS
Get all contact info
