GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Lexus GX 470/460 Wheels
Old 06-01-15, 04:04 PM
Italy6
Italy6's Avatar
Default Lexus GX 470/460 Wheels
I've seen numerous photos of GX 460 18" wheels on 2004-2008 GX 470's
Can I buy 18" 460's & put em in my
08' GX 470 ? Do I need larger lugs ?
One company couldn't guarantee that they would fit. Any feedback much appreciated
Old 06-01-15, 05:49 PM
ALAN553
ALAN553's Avatar
Perfect fit, I believe offset and tire diameter are the same also, just lowered tire profile, 60 vs 65.
Old 06-19-15, 06:56 PM
Lextech43
Lextech43's Avatar
I put these on a month ago. Used the same size tires as on the GX460. I used the same lug nuts also. No rubbing on turns or when suspension moves. They are very close to the same size as the !7s.
RoccoL (07-12-23)
Old 06-20-15, 02:26 AM
ALAN553
ALAN553's Avatar
same revs per mile I.e. Circumference. They are just a lower profile, 60 instead of 65 so height of side wall is shorter...not better for flats or off roading but we already know that 99.9 % of use is dragging the kids around.
Old 07-07-23, 01:28 AM
Franelope
5th Gear
Franelope's Avatar
Default Rubbing
I put stock 460’s on my 470 and they are rubbing! I don’t understand why they are but they are. Can anyone tell me why? 265/60/18
Old 07-07-23, 07:13 AM
ALAN553
ALAN553's Avatar
no idea...shouldn't be
Old 07-07-23, 06:10 PM
delz05
delz05's Avatar
Perfect fitment on my 08... and I used Tacoma Limited 18" wheels!
Old 07-08-23, 08:56 AM
ASE
ASE's Avatar
"Wheels" need to be defined ... assuming the rims are specifically designed for the Toyota/Lexus 6-Lug and are 106.1mm hub centric. All Toyota/Lexus rims meet this specification (4-Runner / FJ Cruiser /Tacoma)... but the offset may vary.
These posts drive me crazy ... Tire Size ? ... Rim Diameter / Width / Offset ? All of these variables add up to a non-rubbing or rubbing situation.
Even the specific tire (tread profile) can cause rubbing.
Old 07-08-23, 12:06 PM
ALAN553
ALAN553's Avatar
The question was “stock” gx 460 wheels mounted with stock tire size. They are the same dimensions, 18” wheels with lower profile tire, i.e. shorter sidewalk height, offset is the same 25. If they rub something in the wheel well is off.
Old 07-08-23, 12:57 PM
ASE
ASE's Avatar
Stock tire size ? ... 18" wheels with "lower profile" tires ? ... is the offset the same ? Let's get specific here ... before and after specs ... otherwise this will be an endless post of random advice ...
So how is a wheel well "off" ? ... please explain.
Old 07-08-23, 01:35 PM
ALAN553
ALAN553's Avatar
dont understand what your question is...2010 gx460 just changed wheel size from 17" to 18" and used 60 profile tires vs 65, this keeps the tire dimensions the same, offset, width circumference, revolutions per mile...get a tire chart and check it
Old 07-08-23, 05:17 PM
ASE
ASE's Avatar
All good ... only if the OP did their homework ... and does not now have an aggressive tire tread (even with the same tire size) that can cause lead-in interference to the front body mount or to the front fender hardware. All of these variables matter.
Too many posts are fixated on "Tire Size" with absolutely no clue as to how rim width and offset plays into the consideration.
Old 07-17-23, 01:28 PM
Franelope
5th Gear
Franelope's Avatar
Default I’m still lost
I still can’t figure out why my tires are rubbing on the right side only. I have a 2008 GX470 Sport with KDSS AND 2012 GX 460 stock wheel on it. Rubbing on the right side. I’d really like to figure this out. I can go back to stock wheels but I think that they’re going to run as well.
Drivers side no rub
Passenger side rubbing and a different looking interior
Old 07-17-23, 02:02 PM
chiph9
chiph9's Avatar
Check your alignment.
But I would guess the fender liner is out of shape. You can probably use a heat gun and move it to where it doesn't touch any more.
Chip H.
Old 07-17-23, 02:45 PM
ALAN553
ALAN553's Avatar
Chip H.
I agree, it’s got to be the liner….
Quick Reply: Lexus GX 470/460 Wheels
