2007 GX470 window problems
All my door windows, except the drivers side window won't operate. The mechanick would wiggle the wiring on the mater control on drivers side, and get them to working. Once he raised the side door panel and got them to start working, along with the drivers door radio speaker even started working, that was a treat. I purchased a new master control window operator for drivers side, still no help on the windows. The doors lock & unlock, just not any help with windows. Is there a wiring harness from the master controller to where ever that can be changed out? Would the ignition switch be the culprit? I checked under the hood, and all fuses were fine.
Try this:
1. Disconnect the negative terminal on the battery, wait 2-3 minutes, then reconnect (try to minimize any sparking).
2. Then go to each door and hold the down button until the glass goes all the way down, and continue to hold for 15 more seconds.
3. Then lift up on the switch and wait until the glass goes all the way up, and continue to hold for 15 more seconds.
That door should work correctly afterwards. Repeat for the other doors, walking to that door (i.e. don't use the driver's door controls for passenger doors)
Archi
RX - 1st Gen (1999-2003)
04-18-18 01:26 AM
