12V Power outlet failure on 1st gen GX470
Old 04-10-15, 03:42 PM
slacknup
slacknup's Avatar
Default 12V Power outlet failure on 1st gen GX470
I was using the12V power outlet to power a small air compressor to a small air tank. Had to answer a phone and forgot about it for a while. When I returned, the air compressor was not working. I figured I either blew a fuse or fried the compressor. I pulled the 12v plug from the power outlet and inserted it in the cigarette liter outlet and the compressor still worked.
I then plugged my radar detector into the 12V outlet and it did not work.So I figureed I blew a fuse. I pulled the 15 amp fuse from #54 but it looked good. To double check I swapped this fuse with the 15 amp fuse for the rear wiper and the fuse was fine.
So I am thinking the 12V power outlet socket must be bad. Isn't that why we have fuses -to protect an expensive part with a cheap one? Is this an easy DIY job?
Thanks for any comments.
Old 04-10-15, 04:55 PM
LexRex
LexRex's Avatar
Often the outlet has a built-in fusible link. You can take it apart and bypass the fusible link, as seen in the following video.
Old 01-22-17, 09:16 AM
Primadanna
Primadanna's Avatar
Default Ne
I also need help on this department. Any takers?
CobraGSF
07-08-19 10:58 AM
dacommitte
NX - 1st Gen (2015-2021)
02-15-19 08:52 AM
Mantist
07-05-18 06:18 PM
ycharlie
RX - 3rd Gen (2010-2015)
06-17-14 01:03 PM
Jaden1
04-11-14 06:43 PM
Quick Reply: 12V Power outlet failure on 1st gen GX470
