GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
TPMS compatibility?
Old 04-05-15, 02:59 PM
NTH
NTH's Avatar
Default TPMS compatibility?
My current wheels are original and I've been thinking picking up some Tundra or 4Runner wheels. I know with BMW wheels, MY11 and newer tpms sensors will not work on, say an 07 or 08. They are on different frequencies. Are Toyotas the same? How did you all get the newer wheels/tpms to register on these older GXs? Better yet, can you disable tpms light? Thanks.
Old 04-06-15, 08:35 AM
470SNC
470SNC's Avatar
oem toyota wheels should be fine to use TPMS sensors and should be compatible
Old 04-06-15, 03:17 PM
NTH
NTH's Avatar
Good to hear. Thanks Sang!
Old 04-07-15, 09:45 AM
techrep
techrep's Avatar
And you can not disable TPMS... and sensors can be swapped from old to new wheels...
Old 04-07-15, 02:37 PM
shadowmite
shadowmite's Avatar
You most certainly can disable TPMS (https://www.clublexus.com/forums/gx-...e-sensors.html), many have done it. But, I strongly advise not to. It's a very useful sensor system that covers cases that go beyond the idiot light. What if you're driving on the highway and get a leak? This can alert you before you destroy a tire. Yes we should all be in the habit of looking at the tires before driving, but TPMS is far more useful than just that scenario.
Old 04-07-15, 03:25 PM
NTH
NTH's Avatar
Im picking up a second set of 4 wheels this weekend. I will swap out just the 4 and leave the original spare with tpms there. Will this be a problem with registering the second set at dealer?
Old 04-07-15, 07:10 PM
Ali SC3
Ali SC3's Avatar
They will just swap the same sensors to the new wheels, should be compatible with most toyota 6 lug wheels. No need to register anything since is the same sensors.
Old 04-07-15, 07:35 PM
NTH
NTH's Avatar
Ali- 4 new wheels already have sensors of their own. Will new set register with just 4 instead of complete set of 5 with spare included?
Old 04-08-15, 08:04 AM
Ali SC3
Ali SC3's Avatar
you will have to go to the dealer each time and pay from what I am reading on other forums, but it will work. not sure if the GX is different in that it can store more than 5 codes but if its like the tacoma it needs a reprogram.
this is a good read, same system, different truck
http://www.tacomaworld.com/forum/whe...-road-etc.html
Old 04-08-15, 09:48 AM
NTH
NTH's Avatar
Good info. Thanks
Old 04-08-15, 10:24 AM
techrep
techrep's Avatar
I should of said legally...
Old 04-08-15, 01:26 PM
chiph9
chiph9's Avatar
What about the winter-tire switch under the steering wheel?
Can he not get his other tires registered with it in the secondary position?
Chip H.
Old 04-08-15, 02:05 PM
NTH
NTH's Avatar
Chip- Good point. So technically I can have a second set registered with only 4 wheels and be ok. I doubt anyone runs 4 plus a spare as a winter set. Thanks for the thought.
forksports
LX - 3rd Gen (2008-2021)
06-13-18 04:51 PM
10lexISR6
04-19-16 04:24 PM
anonymous1
02-08-10 09:18 PM
tukai
09-30-09 01:13 PM
girvan
07-31-09 09:34 PM
Quick Reply: TPMS compatibility?
