Uhaul Hitch Receiver Issue
Hi Guys,
I need to tow a 12' trailer this weekend and was looking over my towing package and noticed an issue. The previous owner had a frame mounted Uhaul receiver installed, however, the receiver bar completely blocks the trailer wire plug (pictures below). If the previous owner had this installed, they obviously towed something, maybe just a bike rack? How would they have been able to hook up the trailer wiring? Any ideas on what I should do here?
yeah, they probably just used it for a bike rack or similar.
Short term: I'd unbolt it and zip-tie it to the tube. Make sure it doesn't hang too low.
Long term: Talk to a welding or body shop about welding it to the tube (and painting it to prevent corrosion)
Chip H.
Chip H.
Easiest way is to just unbolt those 2 bolts, slide it down the bracket, then you can plug the wiring harness. Just make sure it doesn't hang too low, zip tie or whatever. But if you're gonna be doing this more often, just swap out the tow hitch to an OEM tow hitch, it relocates the bracket for the wiring harness plug so it won't be behind it like that.
Just a quick update on this, not that many would have this same issue. I unbolted and slid the harness plug downward. The trailer I'm towing is a 4 pin so I plugged in my 7 to 4 pin adapter and just screwed one of the bracket ends to the harness plug. Just enough so it hangs down past the receiver bar. No need for a zip tie, this should do the trick temporarily.
It's probably about cost, and not having a bracket that gets bent in shipping.
Chip H.
Chip H.
