Battery light on + whining noise
Old 03-18-15, 12:15 PM
shadowmite
shadowmite's Avatar
Default Battery light on + whining noise
So about 3 or so weeks ago I brought my 2006 GX470 into the Lexus stealership and had the pulley's, water pump, and timing belt replaced. Fast forward to this morning, about 300 miles driven and it suddenly when started today has a terrible whining sound and the battery light is on the dash.
Any ideas? I need to go over the invoice from what they did but I believe it was 4 different pulley's they wanted to replace. Not sure if it was anything on the accessory belt path, but I imagine if I call they will blame the alternator and tell me to shell out hundreds more?
I didn't run it long like that, only a minute or so. Popped the hood and I could smell the burning rubber smell so I quickly shut it off. Nothing *appeared* seized to me however.
Old 03-18-15, 12:22 PM
470SNC
470SNC's Avatar
it may be the alternator whining which means its going to go bad soon
Old 03-18-15, 12:44 PM
mrblister
mrblister's Avatar
if battery light is on then car is not charging. You may have a bad bearing in the alternator making the whine as well as sounds like it burned out. There is only one belt on the gx470 and there is a pulley tensioner. Your problem sounds like its all alternator
Old 03-18-15, 01:16 PM
shadowmite
shadowmite's Avatar
I guess I was just hoping it might be something they caused so I don't have to pay out more! I'll find out tomorrow I'm guessing, going to have it towed to the shop in a bit.
Old 03-18-15, 01:52 PM
NTH
NTH's Avatar
I've had 2 whining incidences with cars in the last 10 years. One was a bad power steering pump in a 1 year old Honda. The other was a failing idler pulley on an old Jeep. Hope it's nothing too costly for you.
Old 03-18-15, 02:01 PM
470SNC
470SNC's Avatar
I had the exact same symptoms on my FJ cruiser, battery light came on, battery died, and when I jump started it, alternator started whining. It was the alternator, replaced and good as new.
Old 03-18-15, 07:14 PM
Randy20g
Randy20g's Avatar
I just did the alternator on my gx. Have a look at the pics I posted. I was able to do it from the passenger wheel well with minimal fuss.
https://www.clublexus.com/forums/gx-...ml#post8944424
Old 03-21-15, 10:10 PM
shadowmite
shadowmite's Avatar
FYI as a followup, it was in fact the alternator went bad. must have had a bearing go bad and broke a wire somewhere as it was putting out no power at all.
On the downside, $700 that could have only cost me $150 if I did it myself. Live and learn.
brdnuss
12-27-17 10:54 AM
polypheus
09-16-16 06:48 PM
s6arface
04-25-13 11:32 PM
ULTiMaX99
09-23-12 07:32 AM
bwils
14
03-01-12 03:47 PM
Quick Reply: Battery light on + whining noise
