GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Headlight assembly replacement
Old 02-25-15, 05:40 PM
itzjake
itzjake's Avatar
Default Headlight assembly replacement
So the dealership told me that my GX470 has a "melted housing" inside my driver's side headlight assembly. They quoted me at $850+ for replacement. I was able to find tons of replacements online. However, I noticed a huge difference in price between the sport package headlight assemblies (more like a smoke color) and the original base trim headlight assembly. I have an 04 so anything 03-09 should fit. My questions is: is there a difference between these two parts other than the color of the lens? Could I purchase the sport package headlight assembly and still be able to fit it into my base model GX470? Each headlight is $100 less if I were to purchase the sport pkg which is why I am asking. Any help would be appreciated.
Old 02-25-15, 08:06 PM
YoshiMan
YoshiMan's Avatar
The Smoked ones are nothing but a color difference, and are alot rarer than the regular ones, hense the pricing difference.
Old 02-25-15, 08:20 PM
itzjake
itzjake's Avatar
Yoshi, thanks. I think I will just get 2 new of the sport ones since they are cheaper. Thanks again.
Old 02-26-15, 06:33 AM
IanB2
IanB2's Avatar
Make sure you get OEM assemblies, aftermarket won't be near the same quality and you'll see it in the light output.
Old 02-26-15, 07:54 AM
GXallday
GXallday's Avatar
Just curious, if you're using the same bulb/HID kit, and same projector, how could the housing make a difference in light output?
Old 02-26-15, 08:42 AM
coloboardi
coloboardi's Avatar
Has anyone replaced their headlight assembly with these Amazon ones?
Sport:
Amazon.com: Lexus GX470 03-09 HeadligHeated Unit with Sport Package RH USA Passenger Side: Automotive Amazon.com: Lexus GX470 03-09 HeadligHeated Unit with Sport Package RH USA Passenger Side: Automotive
Non-sport:
Amazon Amazon
Mine look absolutely terrible and looking to replace both units.
Old 02-26-15, 09:15 AM
470SNC
470SNC's Avatar
I hear the Depo aftermarket replacements are good to go
Old 02-26-15, 09:45 AM
IanB2
IanB2's Avatar
Differences in the reflector, and lense could definitely vary the output, it's also possible bulb placement within the housing could vary slightly. I had an accident repair on our '05 Legacy a few years back, they replaced one of the headlights with a quality aftermarket, and the cutoff on the OEM was crisp and white, while the aftermarket was a wide, rainbow colored cutoff line for the lowbeams (projector lense, non-HID).
I'm not saying that someone walking through a parking lot is going to spot the difference while you're parked, or even someone you pass while driving with the lights on, but there is a difference in quality, and if you're like me you'd notice, and it would bug you.
I took the car back and showed them, and they replaced with OEM.
Old 02-26-15, 11:15 AM
itzjake
itzjake's Avatar
OEM would be nice. However, you know the other potential consequences that come with that.
Old 02-26-15, 07:07 PM
GXallday
GXallday's Avatar
As I said before, use the original projector. Then there's no difference
Old 02-27-15, 06:43 AM
IanB2
IanB2's Avatar
Not everyone is equipped to swap projectors from one housing to another, but I suppose that would negate any differences.
Old 02-27-15, 08:36 AM
Booyah
Booyah's Avatar
How did the headlight housing melt in the first place?
Old 02-27-15, 07:36 PM
itzjake
itzjake's Avatar
What I was told by the dealership was that the OEM pigtails for the lights have a tendency to spike the voltage. Not sure if this was the culprit but they wouldn't even swap out my turn signal light because they couldn't cover their *** if something worse were to happen.
Old 03-03-15, 12:37 PM
DJHGX470
DJHGX470's Avatar
Sport: Amazon.com: Lexus GX470 03-09 HeadligHeated Unit with Sport Package RH USA Passenger Side: Automotive
Non-sport: http://www.amazon.com/Lexus-HeadLigh...3NR4VJBFJCS3FB
Yep. I am running a pair. No issues so far and look way better, but I would not expect OEM quality or output.
GX1 by DboyDub1, on Flickr
Old 03-04-15, 02:00 PM
coloboardi
coloboardi's Avatar
Very nice! Are those the sport or non-sport ones? I'm leaning toward the sport headlights.
Quick Reply: Headlight assembly replacement
