Best Diagnostic Scanner (code reader) for Lexus?
Old 01-17-15, 08:53 AM
gordie
gordie's Avatar
Default Best Diagnostic Scanner (code reader) for Lexus?
I have 3 lexi: '01 RX, '05 GX, '12 GX
The older 2 have over 100K and periodic CELs. Rather than continuing to track down places to read the codes for free I'm ready to invest in a scanner. I was about to buy a cheap one off Amazon made by Actron (or similar) then I started reading about something called Techstream on the CL forums.
Is this my best bet for more detailed diagnostics and Lexus-specific code reading?
http://www.ebay.com/itm/Mini-VCI-16-Pin-OBDII-Cable-Cars-Diagnostic-Scanner-For-TOYOTA-Techstream-w-CD-/151410246033?pt=LH_DefaultDomain_0&hash=item2340c10191
If not that particular Techstream can someone send me a link to the one I do need? Or is a $20-$50 Actron or Innova or MaxiScan the way to go?
In case it's not implicit, my goal is to diagnose problems and possibly fix them myself (or at least research the relevant fix), not simply turn off the CEL light.
Old 01-18-15, 05:01 PM
TURBO5DAVE
TURBO5DAVE's Avatar
Techstream works wonders. Can activate different things and change settings on your vehicle. Factory scan tool capability.
Old 01-19-15, 06:59 AM
IanB2
IanB2's Avatar
I bought a "techstream" cable and software off amazon, looked similar to that pictured above. I haven't had a chance/reason to try it out yet, so I can't say if it works as advertised.
Old 01-19-15, 08:58 AM
470SNC
470SNC's Avatar
you can also get a scanguage or an ultragauge for a little less $, both are awesome
Old 01-19-15, 06:43 PM
bjo71
bjo71's Avatar
Thanks for the tip on the techstream, I picked up a cable on amazon prime for $28 with 2day ship. Hope it is good to go. Im used to the BMW world with all the code readers and software to reprogram features and clear codes. Nothing like saving $125+/hr diagnostic charges.
Old 01-20-15, 10:19 AM
LexRex
LexRex's Avatar
I have Torque on my phone, an Ultragauge, and just ordered the Techstream thingy from Amazon.
I like the Ultragauge best for long term, everyday monitoring of things like coolant temperature and MPG, and Torque is nice for quick and dirty code pulls or seeing what an O2 sensor is doing if the Ultragauge is not installed. I only bought the Techstream thing to disable the auto-retracting steering wheel and set all the door locks to open with one button press.
Old 01-20-15, 10:44 AM
burny
burny's Avatar
Techstream for $30 off Amazon is the Animal you want. I have programmed new keys, cut off steering wheels going up and down when starting and cutting off engine, running lights, etc. Also gives you detailed engine specs. I use it on all 3 of my cars
Gene01
Gene01's Avatar
Just be aware that at least some of the techstream packages will only run on a 32-bit OS.
The PC can be 64-bit, but the OS must be 32-bit.
Old 01-20-15, 12:13 PM
bjo71
bjo71's Avatar
Cool. Glad to know it can reprogram those little annoyances.
Old 01-22-15, 10:21 AM
bjo71
bjo71's Avatar
Got the techstream from Amazon last night. Installed on a Win7 32bit laptop easily. Reprogrammed the DRL, the auto alarm arm to 60sec, and removed the auto steering wheel telescoping feature. Pretty nice and easy to work with. Thanks for the tip Turbo5Dave!
Old 01-22-15, 12:19 PM
LexRex
LexRex's Avatar
Got mine last night too. Hooked it up to a Win XP laptop. It connected to the truck fine and was able to read the ECU data fine. However, I bought this to change the Personalized Settings, but that did not work. It got to the first screen for changing settings but any screen after that was blank. I spent 2-3 hours screwing around with it but have reached the tentative conclusion that the cable was defective. Will send it back and try another. This was the Fotga cable on Amazon.
Old 01-22-15, 12:26 PM
bjo71
bjo71's Avatar
This is the one I got.
Amazon.com : Fotga Newest V8.00.034 MINI VCI for TOYOTA TIS Techstream Diagnostic Cable & Software : Toyota Mongoose Cable : Car Electronics Amazon.com : Fotga Newest V8.00.034 MINI VCI for TOYOTA TIS Techstream Diagnostic Cable & Software : Toyota Mongoose Cable : Car Electronics
Old 01-22-15, 01:51 PM
LexRex
LexRex's Avatar
Software comes with it, on a mini CD, but can easily be downloaded off the net.
There are a good number of forum threads on the net where people have gotten the cable driver to work with 64 bit systems, but you would be best off doing your own search for the specifics. The actual Techstream software apparently works fine on 64 bit systems. The cable driver is the problem.
Old 01-22-15, 01:53 PM
LexRex
LexRex's Avatar
There has been some concern about the software having a Trojan in it. I would proceed with caution, but am not sure how legit that concern is. I installed mine on a throwaway laptop.
Old 01-23-15, 05:02 PM
LexRex
LexRex's Avatar
I dunno, but I've noticed that since I tried it the other day I've been getting ads for Viagra on the Nav screen.
Quick Reply: Best Diagnostic Scanner (code reader) for Lexus?
