GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Those Crazy idiot Lights
Old 12-10-14, 08:15 PM
LVLEXUS
LVLEXUS's Avatar
Default Those Crazy idiot Lights
My concern(s)
2 VSC and 1 Check Engine Light just came on......
New gas cap
109,000 miles....
Every service done a the dealership
Was informed that there is up to 4 O2 sensors....
Dealership wants 500.00 which includes labor for each sensor
Thoughts,,,,Suggestions
Time to let it go???
New tires
New timing belt
New water pump
New thermo
New front and rear shocks
Garage kept
ALL RECENTLY DONE!!!!!!!!!
Old 12-10-14, 08:26 PM
Johnny Rad
Johnny Rad's Avatar
Sell it?! I don't understand.
Even if it's an '03, I gotta believe it's worth more than $10k.
Plus, your maint should ensure a solid automobile for the long-haul. Consider this a bump in the road.
I'd be surprised if an Indy wasn't less dough for this job.
Old 12-10-14, 09:56 PM
yardie876
yardie876's Avatar
I have an '03 Sequoia that we have had these three lights on for years. It has been an ongoing battle with Toyota (up to regional corporate) to fix with no avail. The "remedies" have all included a new gas cap, topping off brake fluid, replacing brake booster (at a tune of $1200+), changing VSC computer (somewhere in the thousands also), and O2 sensors, but no one can tell us what the problem truly is without requiring us to pony up and replace all these components with no guarantee the issue will be remediated. I have just decided to drive more cautiously knowing that TRAC and VSC are not there to catch me if I fall. Considering many components on the GX and Sequoia are shared, I'd take a wild guess that this is probably what you're experiencing too. Other than this, the Sequoia has been bulletproof and has taken my family cross county (literally) numerous times.
Old 12-11-14, 07:06 AM
kamlung
kamlung's Avatar
have they read the engine code to see what is tripping the CEL?
Old 12-11-14, 03:30 PM
LVLEXUS
LVLEXUS's Avatar
Default Lesson Learned
If you need a new gas cap...for 18.00 from the dealership.....BUY IT!!!!
PROBLEM RESOLVED!!!!
Good to go for another 200,000 miles!!!!!!
Old 12-11-14, 04:05 PM
BlackCat81
BlackCat81's Avatar
If you think a gas cap is going to fix an o2 sensor code, you're very wrong.
Old 12-11-14, 07:09 PM
LVLEXUS
LVLEXUS's Avatar
Gas cap was the guilty party!!!! I never thought a gas cap was going to fix an 02 error code.....
Maybe BlackCat81 missed the msg
Old 12-11-14, 07:26 PM
Johnny Rad
Johnny Rad's Avatar
Congrats!
Happy holidays
Old 12-13-14, 04:02 PM
BlackCat81
BlackCat81's Avatar
It didn't/it won't. Evap system codes are very different than O2 codes. Either you had evap codes, or you have O2 sensor codes, or both. One won't fix the other. If you replaced a fuel cap and cleared the O2 codes, the light will return. Neither one are registered as first trip priority codes like misfires are, meaning they can take several trips to return once parameters for failure are met. But what do I know, I only do it for a living.
Old 12-13-14, 08:15 PM
LVLEXUS
LVLEXUS's Avatar
Default Lights OUT!!!!
Well, you do that for a living...Happy for you... But would not allow you to service my GX!!!
The tech at the dealership fixed it in less than 5 minutes.......IT WAS THE GAS CAP!!!! NOTHING LESS NOTHING MORE!!!!! THERE WAS NEVER ANY O2 SENSOR ISSUES!!!!
News at 5 film at 11!!!!
Old 12-14-14, 05:41 AM
BlackCat81
BlackCat81's Avatar
Then it had evap codes and not any O2 codes. Gotcha. You're the one that mentioned they wanted to replace O2 sensors for $500, so I made the assumption it had codes relating to them. It obviously didn't.
Old 12-14-14, 09:05 AM
LVLEXUS
LVLEXUS's Avatar
Default Check Engine Light
CHECK ENGINE LIGHT came and went.
Just a worn gas cap that did not cost me a gazillion dollars at the dealership.
Thanks for your concern Johnny RAD and BlackCat!!!!
ALL IS GOOD
HAPPY HOLIDAYS TO ALL!!!!!
Old 12-14-14, 09:15 AM
UpStarr
UpStarr's Avatar
ALL IS GOOD
I've been watching this thread to see if anyone would chime in with a "cut the wires" comment Bahahhahahahah!!!! Glad to hear it was simple Some peope just can't accept the fact that it was an easy fix and that they were wrong I might take the proactive road and purchase a new gas cap myself. Thanks for sharing your story.
Old 12-16-14, 07:52 AM
LVLEXUS
LVLEXUS's Avatar
Default Cap it and go!!!!!
The best 18.00 you will ever spend on a gas cap.
p.s......don't go the easy way and buy a cap from the local auto parts store...IT IS NOT THE SAME!!!
Time to load up the GX sleigh and cram in those presents.
MERRY CHRISTMAS TO ALL!!!!
Old 12-17-14, 06:16 PM
LexRex
LexRex's Avatar
My gas cap caused a CEL today. It was a leaky evaporative system p0456 code. Gas cap was obviously shot, as it required, literally, almost zero effort to turn when removing it.
'09 GX, 95K miles
Quick Reply: Those Crazy idiot Lights
