GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
shaking badly after replacing brake pads
Old 11-24-14, 06:43 AM
DirtyGX
DirtyGX's Avatar
Default shaking badly after replacing brake pads
This weekend I replaced brake pads on both axles. No big deal right, jacked the truck up, took the wheels off, removed the calipers and pressed the pistons back in, put in the new pads, replaced the caliper, put the wheels back on.
Ever since then I've been chasing a HUGE vibration. I loosened the front wheel lug nuts and shook the wheels back and forth thinking that they may have not been seated correctly. Then, re torqued the lug nuts. It got better, but is still shaking badly upon braking.
I will do the same with the rear wheels today (loosen, shake, re torque).
It's not brake warp, the discs were not warped before I replaced the pads.
What did I mess up?
Old 11-24-14, 07:08 PM
BlackCat81
BlackCat81's Avatar
What did I mess up?
Sounds like you may have a sticking caliper now. Did you machine the rotors or just pad slap it?
Old 11-24-14, 09:25 PM
OG Dada
OG Dada's Avatar
Are you past the brake-in point of the brake pads? I think you need to brake them in first for a week or 200 miles before doing any hard braking. If it doesn't happen during braking, then yeah, you might have a sticking caliper problem.
Old 11-25-14, 06:03 AM
DirtyGX
DirtyGX's Avatar
Pad swap only.
I did jack the vehicle up, loosen the lugs, wiggled everything around, re-tourqe. It's barely noticeable now, there is some vibration still, but very little.
Old 11-25-14, 06:27 AM
chiph9
chiph9's Avatar
Did you lubricate the guide rods?
Chip H.
Old 11-25-14, 07:29 AM
DirtyGX
DirtyGX's Avatar
Chip H.
Yes, as well as lubing the portion of the brake baking plate that contacts the channels the plates slide in.
Old 12-01-14, 09:24 AM
techrep
techrep's Avatar
what brand pads ?
Lexus GS3
08-14-15 12:07 PM
shyguyF
09-21-14 05:47 PM
Och
Suspension and Brakes
09-14-11 11:56 PM
e-man
03-01-07 07:49 PM
Quick Reply: shaking badly after replacing brake pads
