Brake Recomendations
I'm running Hawk LTS pads all around, Centric rotors up front, Brembo blanks in the back. I've been very happy with them so far.
while i have not had a chance to run them on my GX yet(will convert over when it comes time to do brakes), i have always had good luck with LCE (LC Engineering) and their slotted and cross drilled rotors -i know there is a huge debate on the blanks vs drilled/slotted, and it goes back and forth. i have run both type is several applications. i have found i have less rotor warping with the drilled rotors. anyhow yeah LCE makes a set that will work and be a good option if you want a sporty look that is also just as functional...
front rotors
http://www.lceperformance.com/Cross-...-p/4544127.htm
rear rotors
http://www.lceperformance.com/Cross-...-p/4544128.htm
i will be running this on my GX within the next 6months
front rotors
rear rotors
just had front brakes done today, centric pads and rotors lasted 50,000 front, rears still good with 45,000 on them and approx 5-10,000 expected. never got more than 30,000 on OEM..truck now has 154K so i have had my share of OEM pads,
