GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
6500lb hitch for GX470, PT228-60540
Old 07-21-14, 06:34 PM
fhartgrave
fhartgrave's Avatar
Default 6500lb hitch for GX470, PT228-60540
If you have a towing prep package on your GX470 up to year model 2009 and you want the 6500lb hitch, get part # PT228-60540. It bolts on, no problem with all of the hardware you need included. This is a class IV 6500lb factory hitch.
Complete instructions are at:
http://lexus.sewellparts.com/pdf/PT22860540.pdf
Attached Thumbnails 6500lb hitch for GX470, PT228-60540-win_20140721_203201.jpg
Old 07-22-14, 05:26 AM
RCsGX
RCsGX's Avatar
Um ok....
Old 07-22-14, 06:44 AM
chiph9
chiph9's Avatar
That's the frame-mounted hitch. The only problem I had with mine was getting the tow hook bolts off. Waaaay too tight from the factory...
Chip H.
Old 07-22-14, 10:20 AM
mrblister
mrblister's Avatar
Chip H.
I needed an Impact wrench
Old 07-22-14, 01:33 PM
fhartgrave
fhartgrave's Avatar
Default Use WD40 on old fine threaded holes
I used a 1/2" breaker bar to bust the bolts loose. You are correct, they are tight.
The only problem I had was the previously unused threaded holes needed WD40. They are all fine threads and they'll be a little rusty/dirty since most of them have been unused for years.
Old 07-22-14, 04:28 PM
mrblister
mrblister's Avatar
I sprayed mine with deep creek used a wire brush to go in and out then I chased the threads with a tap
bolts went in like butter.
Old 07-23-14, 10:36 AM
470SNC
470SNC's Avatar
damn wish that hitch didnt hang so low, first steep climb on trail and that things diggin into the dirt
Old 07-23-14, 12:48 PM
chiph9
chiph9's Avatar
It's not that bad - you'd be hitting the exhaust too. But I admit that you would want to get any tall rocks to go off to one side... Which you'd probably have to anyway to clear the pumpkin.
Chip H.
Old 07-23-14, 12:49 PM
470SNC
470SNC's Avatar
I already deleted the resonator and I see in the future deleting the tip for a turn down instead
Old 07-23-14, 04:50 PM
ST2Alpha
ST2Alpha's Avatar
My baddie's got a GX with that hitch and every time we come off the boat ramp it drags coming out of the water. Partially the design of the boat ramp also.
Alpha
Old 07-24-14, 09:51 AM
470SNC
470SNC's Avatar
yup I plan on getting a custom rear swingout bumper with the hitch integrated a little higher up
Old 07-25-14, 02:34 PM
MichaelD86
MichaelD86's Avatar
Has anyone ever towed that much with their GX? I have a 4000 pound boat and would like to take the GX but i feel like it will tax it too much. I just keep taking my Silverado.
Old 07-28-14, 06:45 AM
chiph9
chiph9's Avatar
My brother-in-law has about that size boat (Grady White - nice!) and tows it with his LX. Same engine as in the early GX (4.7 liter, no VVTi), in a heavier vehicle (LX vs. GX) and it does fine.
Chip H.
Old 08-01-14, 08:40 AM
chrisvr6
chrisvr6's Avatar
I pull my rinker 236 with mine. No problem. Pretty sure it weighs around 4k lbs.
Mulligan33
19
09-13-16 08:38 PM
memphisto
06-07-14 08:26 PM
GreggyG
03-15-14 11:29 AM
Mjr Minor
GX460 / GX470 Classifieds
08-17-06 10:51 AM
Quick Reply: 6500lb hitch for GX470, PT228-60540
