GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Did 120k miles service
Old 04-28-14, 11:31 AM
satiger
satiger's Avatar
Default Did 120k miles service
Over the weekend replaced spark plugs, gear oils (front, rear and transfer), PCV valve and brake oil.
Attached are the pictures of old spark plug and PVC valve. Spark plugs looks OK to me for that many miles. PCV did show some light build-ups (very light though).
Of all gear oils, front differential was little thick and brownish, rear was not that bad at all and transfer oil looked like a new oil. I guess severe beating get absorbs by front differential. For records, I replaced all three of them at around 60K at Lexus. This time I used Mobil Synthetic gear lube LS 75W- 90. Front diff drain plug (has magnet) didn't show any metal debris.
After all these changes, when I started SUV I felt it was more responsive to gas pedal (new spark plugs?). Used OEM spark plugs and PCV valve. PCV valve is right next to engine oil filler tube, covered by a rubber mask.
Attached Thumbnails Did 120k miles service-sp.jpg   Did 120k miles service-0427140719.jpg
Old 04-28-14, 02:29 PM
burny
burny's Avatar
pretty work
Old 04-29-14, 12:35 PM
amccaulx
amccaulx's Avatar
Nice! Where is the PCV valve located? I have been meaning to replace mine for good measure.
Old 04-29-14, 02:25 PM
satiger
satiger's Avatar
Facing the SUV from the front (driver side is on the right), PCV is at the right side of the engine block. Right next to where engine oil filler tube (column) meet the block. It is screwed to the block and covered by black plastic/rubber kind of material.
You need to remove decorative middle cover to access it. It costs me $15 from Lexus dealer.
Old 04-29-14, 02:45 PM
Sethro
Sethro's Avatar
it took me awhile to find my PCV a few weeks ago, I never have seen one all cover up with a foam cover like that before.
Seth
Old 04-30-14, 02:44 AM
schan1w
schan1w's Avatar
How did you remove the pcv valve? Mine is on very tight and I didn't want to force it. Also what torque did you set it at? Thanks a bunch
Old 04-30-14, 06:47 AM
IanB2
IanB2's Avatar
I really need to replace my PCV as well, any extra info on this is appreciated.
Old 05-05-14, 06:47 AM
Sethro
Sethro's Avatar
Just took it out with a big wrench, mine was pretty tight too, for the install I just tightened it up with common sence , I could not get a torque wrench in there.
Sethro
Bocatrip
12-28-16 02:43 PM
Jbthompson
09-09-15 08:00 PM
hawkti
07-18-11 03:18 AM
plocke82
Maintenance
05-02-09 11:16 PM
Rock-a-Lex
Performance
17
01-05-09 06:14 PM
Quick Reply: Did 120k miles service
