GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Drivers side running board lights Out!
Old 04-20-14, 06:14 PM
Booyah
Booyah's Avatar
Default Drivers side running board lights Out!
Just noticed this that my passenger side works perfect but drivers side running board lights (both) do not light up---Is there a fuse to each side, I looked and didnt see anything unless Im missing something
Old 04-20-14, 07:38 PM
chiph9
chiph9's Avatar
Did you look for voltage at the connector? Because it's possible that both bulbs went out at the same time.
This happened to me on my college car - was tearing the harness apart when I had a "duh" moment and checked at the connector.
Chip H.
Old 04-21-14, 07:31 AM
IanB2
IanB2's Avatar
I would try swapping bulbs 1st, stranger things have happened than both burning out before you noticed, it is the passenger side after all.
Old 04-21-14, 09:18 AM
Booyah
Booyah's Avatar
Yea I would find it ODD both out at same time--I replaced them with LED's and everything has been great.. Just Both front/back on drivers side running board are out
Old 04-21-14, 10:24 AM
BlairC
BlairC's Avatar
there are two wires that come down from the body and connect at a single location on the back of the running board. lie down roughly between the front and rear doors and look up. mine had broken a single wire at the base of the connector. I see you are in Alaska. I think mine accumulated snow and ice on the wiring, causing it to break.
I haven't taken the time to source a new connector and solder it in yet, but will need to do that repair myself.
Old 04-21-14, 11:20 AM
Booyah
Booyah's Avatar
Wow--Just went out and looked, Bingo broken wire at the connector, thanks for the help now we both need to get it fixed lol. should be simple I think, but the wire is broken off right inside the connector probably just like yours
Old 04-23-14, 03:01 PM
BlairC
BlairC's Avatar
exactly how mine is broken. I just clipped both off so they wouldn't short anything until I can get a real fix in place.
Old 04-27-14, 06:54 PM
Sethro
Sethro's Avatar
Same thing here, an easy fix
Seth
Old 04-28-14, 09:38 AM
BlairC
BlairC's Avatar
Seth
how did you fix, mine looked to be broken clean at the base of the connecter. can you get that connecter apart to fix it?
Old 04-28-14, 08:15 PM
Booyah
Booyah's Avatar
I havent looked into it yet but I may just cut each connector off and do some splicing of wire and heat shrink it, should be fine to do it that way.
Cindyaz
RX - 3rd Gen (2010-2015)
06-27-18 04:35 AM
CharlesGoo
ES - 5th Gen (2007-2012)
04-04-18 01:33 PM
Im1406
06-23-16 09:40 AM
fay31
08-24-09 03:04 PM
96sc
Lighting
09-02-03 08:02 PM
Quick Reply: Drivers side running board lights Out!
