GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Anyone running Cooper Discoverer AT3?
Old 03-10-14, 03:58 PM
Fluid
Fluid's Avatar
Default Anyone running Cooper Discoverer AT3?
I'm considering that tire for some occasional off road use (rocky / AZ). I will predominately drive on paved roads but want the ability when called upon, without changing to a second set of wheels/tires. I've done some reading and it seems many here also like the Nitto Terra Grapplers. I currently have some Michelin LTX M/S2 and concerned they wouldn't work well and get torn up a bit.
Old 03-10-14, 06:27 PM
RCsGX
RCsGX's Avatar
Just a heads up. Discount tire is running a $100 off $400+ promotion until March 16th through eBay.
You can buy 2 tires and get $100 and do another transaction for 2 tires and get $100 off...so $200 off and free shipping. You can only use the promotion 3 times.
Add the 2 tires to your cart and use the following code at checkout: CMOTORS0314
Then go it again for the other 2 tires.
Old 03-10-14, 09:13 PM
Fluid
Fluid's Avatar
Originally Posted by RCsGX
Just a heads up. Discount tire is running a $100 off $400+ promotion until March 16th through eBay. You can buy 2 tires and get $100 and do another transaction for 2 tires and get $100 off...so $200 off and free shipping. You can only use the promotion 3 times. Add the 2 tires to your cart and use the following code at checkout: CMOTORS0314 Then go it again for the other 2 tires.
I'll definitely check that out, thanks for the heads up. I was actually on the phone with discount tire today because I couldn't find them on their website. But I had not seen that promotion.
I recall you are one of the people using the Terra grapplers, how do you like them so far? More specifically, how did they ride on dry pavement? I've never had A/T tires and don't know how loud they will be.
Old 03-10-14, 10:15 PM
RCsGX
RCsGX's Avatar
The Coopers AT3s you're looking at have great reviews.
Regarding the Nittos, there are two 285/60/18 terra grappler tires. One is an XL load (4 ply) and the other is an E load (10 ply), I'm running the XL load. I have almost 30K miles on them. I measured them two weeks ago and there's 7/32" of tread left, new is 13.6/32", so slightly more than half left. If I can get another 15K miles out of them I'll be happy.
This was my first set of A/T tires and I love these Nittos. They ride excellent on dry pavement and do great on wet pavement too. It rains here almost every day in the Summer and I was surprised at how well they gripped on wet pavement. I've used them driving on the beach and dry / wet sand is no problem either. The only thing I haven't had them in is mud.
Noise is almost non-existent. They do make a little noise when going around 40MPH+ but it's not bad at all, nothing like a mud tire humming. I love having a quiet cabin and the noise doesn't bother me at all. If you're listening to the radio at a low volume or talking with a passenger(s) you wouldn't even notice it.
I wouldn't hesitate to buy them again.
Old 03-13-14, 10:55 AM
470reasons
470reasons's Avatar
Thanks for the discount code RCxGX.
I was able to purchase (5) Cooper AT3 LT285/70-17's for $960 delivered.
Guess I just committed myself to doing a lift and installing aftermarket wheels!
Old 03-13-14, 05:53 PM
Fluid
Fluid's Avatar
I don't think I'll be able to take advantage of the $100 discount twice since each tire I'm considering costs ~ $165, therefore under the $400 required limit.
Questions for 470:
1. Did you get the discount twice? Your tire size is bigger than what i'm looking at so you probably crossed the $200/tire threshold.
2. What is method to get wheels/tires mounted, balanced, etc if you have all the parts yourself .. do you know an small Indy shop willing to charge only labor?? I've taken the route of ordering everything from Discount Tire.
Old 03-14-14, 01:23 PM
470reasons
470reasons's Avatar
Questions for 470:
YES! Got the discount by doing two transactions as RCsGX explained. No discount on the 5th tire.
I have an indy shop about 3000' from my house and they have done at least 3 sets for me. Usually get the tires from tirerack.com and have them install and balance. The indy does sell tires, but they don't turn you away if you bring in your own. You should be able to find a similar shop in your area.
Discount tire ships fast. My tires will be here Monday the 17th.
EDIT:
Just got a great deal on 5 Konig Six Shooters
Graphite gunmetal (high gloss, dark gun-metallic grey)
Diameter: 17"
Width: 8"
Offset: 0mm
Backspacing: 4.5"
PCD (Bolt pattern): 6x139.7mm
Centerbore: 108.3mm
Old 03-15-14, 12:43 PM
RCsGX
RCsGX's Avatar
^ That's going to be a nice setup!!
For anyone else needing tires...that deal only last until the 16th.
Old 03-15-14, 01:00 PM
470reasons
470reasons's Avatar
Thanks. Things are starting to snowball. Can't use the tires without a lift and aftermarket UCA's and can't cleanly mount the spare anywhere without a Southern Style Speed rear bumper.
http://southernstylespeed.com/produc...rier-rear.html
Old 03-15-14, 10:22 PM
montanagx
9th Gear
montanagx's Avatar
Would you mind sharing where you got a deal on these wheels? I am looking at the same ones and would love to save a $$ if I can.
EDIT:
Diameter: 17"
Width: 8"
Offset: 0mm
Backspacing: 4.5"
Centerbore: 108.3mm
Old 03-16-14, 09:25 AM
470reasons
470reasons's Avatar
Sure!
I talked to Dustin at FN Wheels.
Got a package deal of (5) wheels, (4) sets of lug nuts (with locks), 2 sets of center caps.
I'm not going to share the price. You'll have to work out your own deal.
http://www.fnwheels.com/
Check this thread:
http://forum.ih8mud.com/120-series-t...-princess.html
Woody bought his wheels from Dustin.
Old 03-16-14, 10:06 AM
RCsGX
RCsGX's Avatar
Dustin's a great guy and FN wheels as a whole is a great company. Browse through some of their threads (google) and look at how great their customer service is.
I've had my BFD wheels for almost 2yrs and no problems whatsoever.
Old 03-16-14, 07:37 PM
Fluid
Fluid's Avatar
RCsGX/470 - how do I find the eBay promo specifically for Discount Tire? I had originally ordered from my local Discount Tire store (a few days ago) and they called me Friday saying the Cooper's were on back order and it could be a few months (?).
I don't use eBay very often but do have an account ... when I navigate to the Tire Center I can find Cooper tires but don't see any for sale specifically from Discount Tire.
Old 03-16-14, 07:55 PM
470reasons
470reasons's Avatar
The eBay site is discounttiredirect
http://www.ebay.com/sch/discounttire...1&_ipg=&_from=
In the search window type: cooper and the tire size you are looking for.
Fluid you better hurry!!!
Old 03-16-14, 08:06 PM
RCsGX
RCsGX's Avatar
If you want the Cooper AT3 in a 265/65/17 size they're in the link below:
http://www.ebay.com/itm/4-NEW-P265-65-17-COOPER-DISCOVERER-AT3-65R-R17-TIRES-/310831159291?pt=Motors_Car_Truck_Tires&vxp=mtr&hash=item485efb17fb
Click the add to your cart under the buy it now button in the link above. Then checkout. Once you're at the check out page enter the code: CMOTORS0314 in the have a redemption box and click apply....and you will get $100 off.
Quick Reply: Anyone running Cooper Discoverer AT3?
