GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
right front caliper is sticking
Old 03-01-14, 03:03 PM
IanB2
IanB2's Avatar
I've used a Raybestos branded brake lube in the past, greenish black, tacky stuff, messy. Sucks that you ordered the wrong caliper, will Sewell take it back as it's a special order? Should be the same as a 4Runner, and they have the same frozen caliper issues as GX's, so you might be able to sell it to someone if you get stuck with it.
Old 03-01-14, 05:46 PM
burny
burny's Avatar
I used white lithium grease on my slide pins. Also used it on the shims
Old 03-01-14, 06:16 PM
fantic
fantic's Avatar
I also use white lithium grease. If the noise is coming from the rear could the parking brake be sticking?
Old 03-01-14, 06:52 PM
RCsGX
RCsGX's Avatar
Yeah they'll take it back because when I ordered it online there was no mention of it being a special order part, it just says it'll ship within 24-48hrs.
Not sure what the problem is but hopefully I'll be able to clean it up, grease the pins and it'll be fine.
Thanks.
Thanks.
I was hoping the emergency brake was engaged but it wasn't. We've never used the parking brake so I doubt that's the problem but I'll know more once I get into it.
Old 03-01-14, 10:23 PM
IanB2
IanB2's Avatar
Originally Posted by RCsGX
Thanks. I was hoping the emergency brake was engaged but it wasn't. We've never used the parking brake so I doubt that's the problem but I'll know more once I get into it.
If it's not used and then activated (maybe by someone who doesn't normally drive it?), it could seize on and be causing these issues. Interested to gear what you find.
Old 03-01-14, 11:08 PM
msn619
msn619's Avatar
I use loctite 8065 C5-A Anti-Seize Copper if its good enough for a dakar rally car its good enough for my cars, but its expensive for a small stick but well worth it lol...
Old 03-02-14, 05:51 AM
fantic
fantic's Avatar
I'm addicted to Anti-Seize. I use the gray stuff. I would use the grease on the caliper slider and Anti-seize on the pins that hold the pads in. I Anti-Seize everything. Maybe in 10 years the next owner will thank me. Wife hates the stuff though. Doesn't come out in the wash,
Old 03-02-14, 07:49 PM
RCsGX
RCsGX's Avatar
I guess having no pad on the piston side will cause a bad grinding noise. LOL
Somehow the inside pad fell out along w/ the upper locator and the pad backing separated from the pad. I can't find the upper locator but the pad and backing plate were between the rotor and dust shield.
I have new rotors and pads being delivered Tuesday but Sewell doesn't have the rebuild kit, piston or upper pad retainer / locator in stock. I have family coming in from out of town Wednesday so I'm in a time crunch. Has anyone used a remanned caliper from Napa? I was thinking of getting the one in the link below, it comes w/ the caliper and pad locators. At some point I'll rebuilt the OEM one.
http://www.napaonline.com/Catalog/Ca...7A_0248611430#
Old 03-03-14, 04:53 AM
burny
burny's Avatar
I used one similiar from Bap Geon on my wife's GS350. It was rear left driver's side. This was a year ago and it is doing fine.
Old 03-03-14, 08:16 AM
RCsGX
RCsGX's Avatar
Nobody has a remanned caliper in stock...I was thinking of deburring the face of the piston but even if I debur it, it won't put an even amount of pressure on the pad backplate so I had Sewell overnight a rear caliper.
After looking at Sewells rear brake diagram I see there are 2 pad wear indicators, 1 for each side. I didn't have one on my passenger side so in case I don't have them on my drivers side can someone tell me where these go? I needed the 2 pad wear indicators and 1 top locator. Since sewell didn't have them in stock I ordered these from amazon:
Amazon.com: Dorman HW13111 Disc Brake Hardware Kit: Automotive Amazon.com: Dorman HW13111 Disc Brake Hardware Kit: Automotive
carlos
Suspension and Brakes
03-04-16 05:37 PM
CincyBrad
05-23-15 12:41 PM
morris
10-24-06 09:14 AM
LexusSara
05-29-06 07:32 AM
Quick Reply: right front caliper is sticking
