GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Used Oil Analysis
Old 03-05-14, 02:21 PM
RCsGX
RCsGX's Avatar
Originally Posted by bhesse
The filter you quote in this thread Purolator PSL30001 is not the OE size called for, is this a bigger capacity filter than :Purolator PSL10241
Yes I know, it's an extra capacity filter IE: holds more oil. The base is the exact same size as the OE filter, it's just wider and longer.
Old 03-21-14, 11:26 AM
bhesse
bhesse's Avatar
thanks, does it fit OK in the space for the OE filter I may switch after I use my Toyota OE
Old 03-21-14, 01:19 PM
MidniteGX
MidniteGX's Avatar
Originally Posted by Hill60
Now I wonder if there is such a website to run the VIN in Canada. Although I did see the complete service history, privacy laws apparently preclude getting a copy. Bugger.
Hear, hear!
The only thing I've been able to do is ask the dealer to run it and they did. Printout was basic. If you want the detailed info, it may be harder to get. Best course of action: bring donuts and just ask. If the answer is no, remove donuts from them and ask someone else.
Old 03-21-14, 03:04 PM
RCsGX
RCsGX's Avatar
Yep fits fine.
Old 03-25-14, 05:31 PM
bhesse
bhesse's Avatar
I just changed mine today and with stock OEM filter it only took 6 qts to fill to middle of dipstick. (Even ran it for 15 seconds after draining to get as much old oil out)
I see many posts stating 6.5 or so, does it vary that much? used Mobil 1 5w-30
Old 03-25-14, 06:43 PM
RCsGX
RCsGX's Avatar
These engines vary between 6-7qts.
leehom
NX - 1st Gen (2015-2021)
10-01-22 09:17 AM
azncapcom
06-15-20 06:51 AM
Brokenis
02-15-17 04:31 PM
itgrowsind
10-27-06 11:35 AM
Quick Reply: Used Oil Analysis
