Rear Window on GX470
I have a 04 GX470 and the Passenger Rear window will roll down but won’t go back up, you can roll it up on the driver’s controls and the key. Is this a switch problem or possibly a relay?
The old switch may be repairable. I have opened up other switches and been able able to clean them . Look at the switch see if there are any medal tabs you can bend out to open it You could also spray the switch with contact cleaner might just do the trick
05ls430518
02-26-18 08:40 AM
