2003 lexus gx470 not running in drive but runs in 4 wheel drive
hi i have a 2003 lexus gx470 the problem is that when in drive it does not move it only revs up but when in 4 wheel drive it does move i put transmission oil in and it did run in drive but broke down again only reved up did not move so im wondering what it could be i was told it was the transmission then just found out from someone else that its some sensor or transfer case? i dont know can someone tell me what it could be and if it has to do with the transfer case or sensor what part do i need?
Put tansmission in neutral while stopped and then slap the transfer case into Low gear; then put transmission back into drive.
Also, Try running the lever back and fourth hard a couple times. (while in neutral)
Perhaps the linkage is sticky, if there was something wrong in the drive train I dont think you would be moving at all.
girlwstyle
GX - 1st Gen (2004-2009)
40
12-17-15 12:09 PM
