05 GX VSC OFF & Center Differential Lock lights on
Old 03-23-13, 08:12 AM
mansito
mansito's Avatar
Default 05 GX VSC OFF & Center Differential Lock lights on
The VSC OFF and Center Differential Lock lights come on yesterday on my wife's 05 GX470. I connected the OBD2 code reader, but it says "no error codes found". Since there are no error codes, I am at a lost in trying to figure out the root cause. Any suggestions?
Attached Thumbnails 05 GX VSC OFF & Center Differential Lock lights on-gx470.jpg
Old 03-23-13, 11:35 AM
IanB2
IanB2's Avatar
Try turning off the center diff lock, just looks like someone hit the button and locked it up, no big problem. The "VSC off" light comes on with the diff lock.
Old 03-24-13, 04:05 PM
mansito
mansito's Avatar
I did that. When I press the center diff lock switch the center diff lock indicator on the dashboard blinks, but it never goes off. I guess a visit to the local lexus dealer is order tomorrow. I'll post when I find a solution to the problem.
Old 03-24-13, 04:16 PM
IanB2
IanB2's Avatar
If it doesn't get used much, it could just be stuck. Try turning it off and driving around in figure 8's in a gravel/loose surface parking lot so it can unbind and release on its own.
Old 03-24-13, 06:53 PM
mansito
mansito's Avatar
Good idea. I cannot recall a time when it was turn-on. I think it has never been used. the GX has never been off-road. I'll try your suggestion tomorrow.
Old 03-25-13, 03:23 PM
mansito
mansito's Avatar
It was stuck from lack of use. Before I took the GX to a gravel area as suggested by IanB2, I read the manual carefully. It suggests to drive it in reverse when the VSC OFF and the Center Diff Lock lights are on. I put it in reverse in my driveway, and before I go to the end of the driveway the lights went off. IanB2, thanks for the suggestion. I bet doing eights on a gravel road would have unlocked the center diff also.
kamele (04-08-20)
Old 03-25-13, 04:27 PM
IanB2
IanB2's Avatar
Glad to hear you got it sorted out!
Old 03-26-13, 05:45 AM
06isDriver
06isDriver's Avatar
i love a happy ending
Old 04-01-13, 07:43 AM
mansito
mansito's Avatar
Agree. Owner forums are great. They provide an avenue to share experiences and educate us on solving problems. I am a DIY on all my vehicles. I do the work not only to save money, but most important for the satisfaction that the work is done right using the highest quality parts. I hope this thread help other owners solve similar problems.
GXFour70 (08-02-21)
Old 04-01-13, 09:48 PM
mann777
mann777's Avatar
That's what CL is all about, we help each other as far as we can, give solutions & at the end of the day the member is happy.
Old 10-27-13, 08:25 AM
TucsonDave
TucsonDave's Avatar
Default Thanks - had same issue, fixed it with your advice
Just a thank-you to you guys for posting this thread. Had the light, envisioned expensive repairs, did some gravel 8's in reverse, all is well. THANKS!
Old 10-27-13, 05:42 PM
Crispy3M
Crispy3M's Avatar
In the old days, backing up was the "tried & true" method for getting any four wheel drive out of 4WD
Old 10-27-13, 05:49 PM
RCsGX
RCsGX's Avatar
I've had my center diff stick once and before I even got to the end of my drive way in reserve it unstuck itself.
The only time I had to do figure 8s was to recalculate my MDXs navigation. Those people on the top level of the parking garage were probably like, what the hell is that guy doing.
Old 10-27-13, 10:45 PM
Crispy3M
Crispy3M's Avatar
I wouldn't dare start doing figure 8's... with my luck I'd end up finding out the CV's are shot... LOL!
Old 10-28-13, 01:21 AM
RCsGX
RCsGX's Avatar
Originally Posted by crispy3m
i wouldn't dare start doing figure 8's... With my luck i'd end up finding out the cv's are shot... Lol!
I have luck like that too.
Quick Reply: 05 GX VSC OFF & Center Differential Lock lights on
