GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Overhead console sunroof homelink is not working anymore !!
Old 03-04-13, 09:39 AM
masboy
masboy's Avatar
Default Overhead console sunroof homelink is not working anymore !!
i pulled it out last week to fix my after market reverse monitor, so when i pulled the console i tested the light make sure i didn't screwed up anything. Then it was turned on for 2 seconds and slowly died. Since then, none of the button work !!! no sunroof, no homelink, nothing, nada !!! helppp....
i've checked fuse already, 27, 35, 36 I believe. i replaced them all, still not working.
Old 03-04-13, 12:20 PM
BlairC
BlairC's Avatar
perhaps it just lost its programing? I am not sure where the actual memory resides, but if you removed it, it is worth considering it might need to be reprogramed.
Old 03-04-13, 01:56 PM
masboy
masboy's Avatar
BlairC, the think is none of the light is working, It's completely dead, none of them is working.
Old 03-09-13, 11:19 PM
mann777
mann777's Avatar
Masboy !
You've mentioned that you replaced the following fuses
""i've checked fuse already, 27, 35, 36 I believe. i replaced them all, still not working.""
The Entire fuse for the above are controlled by a Single Fuse ( within the Engine Bay Fuse Box) which controls the Engine Control Warnings,Interior Lights, Cruise Control,Instrument Control,Sound, Navigation, Homelink and Garage Door Opener, is the fuse located next to the Dome fuse called as ECU-B2 Fuse 10A. This is the one you need to check and replace if required and nothing more.
Old 03-12-13, 11:21 AM
masboy
masboy's Avatar
Originally Posted by mann777
Masboy !
Where is that DOME fuse is, mann777 ? Is it in the front engine bay or the one inside, on the driver side ? My friend tested all the fuse in engine bay, everything seems normal.
thx!!
Old 03-16-15, 08:13 AM
Lance10000
Lance10000's Avatar
Default Where to buy LEXUS GX470 OVERHEAD CONSOLE
I tried to replace the light bulbs with LED LIGHT BULD then seen I was sent the wrong bulb so I tried to wire it to fit new bulb. Of course I mucked it. Anyway talking with Ricky that sells one on eBay he thinks it's the computer on board to operate all that is there. Ricky won't sell me the one he has on eBay cause it won't work on my year. Does anyone know where to get the LEXUS GX470 OVERHEAD CONSOLE?? I've looked everywhere. Any help is appreciated sorry don't know where the fuse is located in previous post. [I have 2006 GX 470 2004 ML 500. The Lexus as everyone can guess blows the Benz away makes the ML 500 seem Smaller. It also totally kills da ML 500 AS FAR AS COMFORT AND UP IN DA HILLS 4x4 .!!! Da GX 470 is da best I've Vehicle I've ever owned .
THE LEXUS 2006 GX 470 was purchased last year with under 50,000 miles from a dealer where a previous Japanesse VP owned it. OBVIOUSLY PREVIOUS OWNER took real good care from the BRAND NES CONDITION of it when I BOUGHT IT. IT WAS BRAND NEW BETTER SLMOST THAN NEW. THE OREVIOUS OWNER he probably only drove it to work and back. Incredible piece of machinery. I love my Lexus GX470👍😉 ][/QUOTE]
Old 03-16-15, 02:56 PM
Ali SC3
Ali SC3's Avatar
his post says its in the engine bay fusebox I want to say its on the drivers side underneath some plastics.
SoCal Cyco
12-01-22 04:29 PM
edvc520
12-01-22 09:46 AM
IamLexus
05-02-10 03:34 PM
LasVegasGS
SC- 1st Gen (1992-2000)
02-21-05 12:01 AM
Quick Reply: Overhead console sunroof homelink is not working anymore !!
