daylight lamp
Old 07-17-12, 08:58 PM
clubsport
clubsport's Avatar
Default daylight lamp
hi y'all:
how do you go about diabling or turning off the daylight lamp? thanx
Old 07-18-12, 07:58 AM
tz693
tz693's Avatar
Originally Posted by clubsport
hi y'all:
take the bulbs off
Old 07-18-12, 08:07 AM
cdew002
cdew002's Avatar
Are you referring to the daytime running lights on the front of the vehicle or something else?
Old 07-18-12, 08:41 AM
clubsport
clubsport's Avatar
i am referring to the yellow lights below the headlamps and above the fog lights... on my infiniti you can turn off that functinality with your headlamp swicth and on my old chevy s10 i could do the same too with a button push...
Old 07-18-12, 11:48 AM
MSGX470
MSGX470's Avatar
Combination running light/turn signal I believe is what your referring to.
Old 07-18-12, 11:59 AM
iJDMTOY
Former Sponsor
iJDMTOY's Avatar
I'm not sure if Lexus has the ability to turn the daytime running lights on and off, but if you don't, you could also pull the DRL Fuse.
Old 07-18-12, 01:58 PM
clubsport
clubsport's Avatar
ok, thanx all guess they will just stay on...
Old 07-18-12, 03:46 PM
redrocks
redrocks's Avatar
Believe that starting with 2010 MY, option on light controls to turn off DRL.
Old 07-18-12, 06:37 PM
cdew002
cdew002's Avatar
If you turn the light switch one notch, the DRLs turn off and that other light comes on - you could leave it on that setting and take out the "other" bulbs. (Not sure what those bulbs are called...)
Old 07-19-12, 12:10 PM
iJDMTOY
Former Sponsor
iJDMTOY's Avatar
I believe that if you turn it one notch, the DRL's are still on. The DRLs only turn off when the main headlights turn on I believe. The first notch is for the parking/license plate lights.
Old 07-19-12, 05:34 PM
cdew002
cdew002's Avatar
You are correct sir.
Old 07-21-12, 03:50 AM
mann777
mann777's Avatar
DRLs are said to improve safety because they increase the visibility of the car to other traffic, especially on shadowy, tree-lined roads and at dawn or dusk. They increase safety as other drivers are more likely to see you.
If you want them removed, just tell your dealer, they will have it de-activated. It can be done without any faults triggering from the ECU onto your cluster. Any other means you would a warning lamp activated.
Personally I did not like the color ( Amber) so I decided to go the LED way.
Old 07-21-12, 09:15 AM
RickC5
RickC5's Avatar
I agree that DRLs are a great addition to safety, especially here in Colorado where we have many 2-lane rural highways, and lots of drivers simply don't pay much attention to what they're doing when they're driving.
If I could ask, what mods did you have to make to switch to LEDs? I wouldn't mind switching, but I don't wish to add resisters, etc. to make the LED bulbs work properly. Plug-and-play is what I'm looking for.
Old 07-29-12, 10:06 PM
mann777
mann777's Avatar
You need to replace the existing flasher unit with the Toyota Denso LED Flasher.
Old 07-30-12, 06:13 AM
RickC5
RickC5's Avatar
Ok, so is it then necessary/required to have LED bulbs in all FOUR turn signals, or can you run two LEDs in front and regular incandescent bulbs in the rear.
Also, since our front t/s bulbs are also our DRL bulbs, which LED bulbs did you use in the front? Several LED bulbs I have found on the web (listed as 1156 replacements) specifically state that they can NOT be used as DRL bulbs. Confusing to say the least....
Quick Reply: daylight lamp
