Need options/opinions: welded nut inside frame broke loose installing hitch
Take a look at this thread. You may not have the correct middle mointing plate for the hitch.
https://www.clublexus.com/forums/gx-...l?ref=esp-link
Look at the picture that shows 2 different center mounting plates. You may need to buy the one that is different then the one that you have.
KODA4.
KODA4.
KODA4.
KODA4.
When I was trying to install the hitch it felt like the issue was the center mounting for the pintle - I even opened the rear most mounting holes on the hitch a tad too see if it made a difference and it did.
I will try and mount the hitch by the rails only and see if it's extending past the center mounting by 1/4" - 1/2" which would be corrected by this other mounting bracket.
If it is the bracket it looks like I'll need to pull the back bumper - yay! Hopefully no more broken bolts
-Eric
KODA4.
KODA4.
Looks like I need to track this part down!
-Eric
Here's some pics from today when I used the frame bolts without the mounting for the pintle:
