GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Gx470 stalls at highway speed but restarts. Help?
Old 07-01-12, 12:34 PM
Faterst
Faterst's Avatar
Default Gx470 stalls at highway speed but restarts. Help?
Hi. I have a 2005 GX470 with 96,000 miles. Yesterday, while going on a 500 mile road trip the car stalled suddenly while traveling about 75mph on the interstate. It would start surging and then just stall completely. I pulled over.. Let the car sit for a minute and then it started right back up with no trouble. It did this to me 4 times on the trip about 80-100 miles between issues. The last time it was while accelerating hard up hill. All other electrical functions.. Radio, lights, etc...continued to work fine. I don't recall the cel ever coming on and even if it did it wasnt on when it restarts. It was 100 degrees out.
I'm on vacation so wanted to get it checked put before we head home but curious on thoughts of what it might be? I was thinking clogged fuel filter or MAS but the fact that it restarts right up after stalling makes me ink it might be more of an electrical issue.
Ideas appreciated.
Old 07-01-12, 03:03 PM
Booyah
Booyah's Avatar
Im thinking a partially cloged cat converter and or its acting at times when it gets hot. thats all i can think of that would do that.
Also I had a car once with almost same symptoms and it was the muffler coming part from the inside and pieces would blow around and block the flow---weird but true.
Old 07-01-12, 06:04 PM
LexGX
LexGX's Avatar
Have you checked your air filter? Fuel filter would be something else to take a look at.
Old 07-02-12, 10:26 AM
SouthernSS
Former Sponsor
SouthernSS's Avatar
a disintegrating cat will cause these symptoms intermittently, blocking the flow. It should store a code though, indicating a primary cat failure. Run by an autozone and see if there are any codes stored.
Old 07-02-12, 05:35 PM
TopGear300
TopGear300's Avatar
The fuel filter in the GX is non serviceable. I have no idea what this frankly big problem could be but figured I would pitch in and tell you to skip the fuel filter
jrmckinley
12-17-16 06:04 AM
Carver
06-11-11 06:18 PM
lexusbooty
IS - 1st Gen (2001-2005)
10-29-09 02:47 PM
2004RX330
01-04-05 11:00 AM
mherold
06-07-04 08:05 AM
Quick Reply: Gx470 stalls at highway speed but restarts. Help?
