oil filter
oil filter
hey anybody knows if the 4runner folks or gx470 people using a longer length filter? seems ours are kind short just seeing if anyone knows a larger size that'll fit our trucks
Lexmex
Super Moderator
1999 Lexus RX
Trader Score: (0)
With our 06 4Runner V8 (same setup as the GX for the oil change), I have been using a K&N HP-2009 oil filter (a bit longer than the stock size) and it has a nut on top to make it easy to remove so I don't need to remove any covers. A bit of a pain to get the new filter in there (have small hands), but works like a charm.
__________________
Homepage of my 1999 RX300 AWD
Super Moderator
1999 Lexus RX
Trader Score: (0)
__________________
I always stick to the Toyota ones because it's cheap and made for the car. I might go with the Royal Purple 10-2835 one of these days. But it might be just as small as the OEM.
Get yourself an oil filter cutter if you're an oil geek and take a peek inside of your used filter to see what it's catching. A Dremel will also do.
why u doggin me?
from your insufficient knowledge of hid setups to ghetto truck setup... you remind me of the many many honda civic ricers who know everything about everything... so annoying but i manage to ignore you and your ugly a$$ truck with no comments...
i'll say it again, if you can't contribute then f... off
Forum Administrator
Clubsport and rok,
Formally asking you to either knock off the public back and forth baiting & jabs or add each other to your Ignore lists
https://www.clublexus.com/forums/pro...?do=ignorelist
Don't expect to see this in future threads....
